Black Bubble/Foam
Hi Guys,
No matter what I do the bubbles are totally black? Litted with HDRI.
The newest downloadable Phoenix.
Hey,
If you go into the V-Ray Object Properties of the Particle shader - are “Generate and Receive GI” options on?
Are the particles rendering black if you use V-Ray Sun or another type of light?
Can you share the scene with a single cache so we can take a look?
Thank you,
Here you go:
The scene seems to be rendering fine in here with both V-Ray Next and 3.60.04. What version of V-Ray are you using?
Can you send us the V-Ray and Phoenix Log files - if you open the Simulator settings there is a Preferences button - from there you can locate the Phoenix log file.
For V-Ray under Settings tab there is a Log location.
Thanks,
Hey,
For rendering with V-Ray make sure to get the Phoenix FD build for V-Ray Next, you’re using the defscanline build.
This is great working like a charm. Thanks, just stupid mistake and so much problem.
