Black window
Can’t seem to get anything besides a black window with no errors (with the demo). Running max 2010. I tried to launch the vray RT server and that has no errors either. Am I missing something?
make the window smaller then 320x240
/Thomas
Is there any message printed in the ActiveShade view?
this most likely. had same issue until i set rt resolution to 320x240
Nothing changes when I reduce the size of both the viewport and popout active shade. You mentioned set rt resolution, where is this located? The only thing printed in the window is “V-Ray RT Demo 32x 240 max resolution for demo”.
Five minutes later: Seems to work now. Had to popout activeshade window for it to reset/fix. Thanks for the help
Running on MAX 9 64bit - i got past the viewport size so i can see the messages and that it sends the scene out to the local render server
but… it stop at “Waiting for image data…” and remains black (i only have 1 teapot in the scene)
Do you see a command-line window in the task bar with the V-Ray RT render server?
No, even though inside the active shade view port is says “Starting local render server (done)”
Ok then, which OS are you using?
Also, in the Task Manager, do you see a process called “vray.exe” running?
I must be doing the same thing wrong.
Active shade pops up and says “V-Ray RT DEMO 320x240 max resolution for demo”
no vray.exe in task manager.
I have render res set at 320x240, and I made the perspective window really small. I just can’t get it to do anything.
vrlservice.exe is running, but that’s it.
this is in max2010 in WinXPx64
You have probably set the resolution for the Production renderer, not for the ActiveShade renderer. Make sure you set the rendering mode to ActiveShade from the radio controls in the lower left corner of the 3ds Max Render setup dialog, then change the resolution to 320x240.
no surprise, but you are correct.
I wasn’t aware it had changed when I switched to active shade settings. Sorry, I didn’t notice. That solved that problem.
I hadn’t used active shade before. Thanks vlado. Quick to solve the problem, as always.
No problem; the ActiveShade workflow in 3ds Max is a bit awkward and takes some time to get used to (I’m not really aware of anyone using this feature since it was introduced in 3dsmax 5 I think).
I am having the same prooblem, everything is correct as per previous threads, bit in the active shade floater window it won’t get past waiting for image data…
Last entry in V-RAY RT render server: Memory Usage:16.18mb
There are no error anywhere and the vray exe is running too!
How long should it usually take, tried with a large scene I am working on and with 1 teapot!
I have just tried it on my 32-bit machine and it works fine.
However on a 64 bit machine, which I have max 32-bit and vray 32-bit it doesn’t work.
I have 32-bit installed as it needs to match my other 32-bit machines so I can use backburner…
I have tried the 64-bit server with 32-bit VRAY RT and that doesn’t work either, is there any way to get this working?
What happens in that case? It is supposed to work, since I’ve used that scenario many times here.
I have tried the 64-bit server with 32-bit VRAY RT and that doesn’t work either, is there any way to get this working?This should work fine, but perhaps it is related to the above issue too.
I have the same black window waiting for image data. I had this working great yesterday with the timer countdown working. Setup ActiveShade & Production Render to 320x240. Started up a seperate activeshade view. everything works and it stuck on the waiting for image data. Vista Ultimate x64 Max2009 64-bit VRay 1.5 SP3a Again, I had this working fine yesterday, but today I get nothing…very strange.
There are several things to check:
(*) Do you have the “Auto-start local server” option in the V-Ray RT rendering settings?
(*) Do you see the V-Ray RT render server window in the task bar?
(*) Do you see the vray.exe process in Task Manager?
Auto-start local server = Checked On
I do NOT see the VRay RT Render server window
I see the vray.exe process running in task manager
When I start the VRay RT Render server from the start menu in windows, I get the following error.
Error: Failed to start network server: Failed to open listening port (10048 ) Exiting server mode.
