Blotch effect after installing new version of enscpape
I noticed after updating to the newer version, that it handles low light much worse then before.
See the 2 renderings of the same model and light. one is 2.6 and the other 2.7 version
  • i know this can be resolved by using lights objects, but this creates much more work, as my project are about 5 per week and 50 renderings. If i need to add light objects to every room in the design for every model it add lots of hours more each week. Also the result i got before with no light object was perfect for my needs.
Any time on how to change this in the new one or do i just need to download an older version and go with that?
@retsac , thanks a lot for your post and welcome to our forum.
First of all, make sure you’re not using emissive surfaces as your only source of light - just in case you have done that in the first rendering, not sure if it’s a line light or an emissive surface.
Furthermore, in that regard you could reduce these artifacts by lowering the “Rendering Quality” in the Visual Settings - this noise is generally cause by Global Illumination, which gets weaker the lower you turn the Quality. It may seem counterproductive at first, but you may wanna give it a try.
Also, I’d still love to check out the project itself which you’ve used in the first rendering (in case you can send it over) - I just wanna make sure, that everything is working accordingly, even though the noise may very well be normal under these lighting situation. Perhaps you could also let in more light from the outside through windows or such? Alongside with setting the sun at the right angle so that it gives off some nice light into the scene, IF that is even possible.
I understand your response, and i know light object are better than emmisive surface. That not what i’m trying to ask. The setup was the same, no additional light objects just 3 emmissive surfaces and natural light. only the other doesn’t have the emmisive surfaces. ( i can’t imagine these has that effect on the light situation, as there is 1 bigger emmisive surface in the new scene) It seems the new enscape handles low light worse, is this possible?
On the otherhand i must say the my other renderings with lots of natural light are much better with the new version. As the renderings need to be fast for my work, i can not add light object to the entire model. Low light situation worked in all previous version.
Other previous models with low light also have worse results also with the new version.
I worked really well before, is it possible that the new version handles low light worse?
thanks for the response!
@retsac , we have made some adjustments to our lighting indeed, you may need to add a few more light sources in that regard now, or make sure that somehow more light is coming into the scene. Or as mentioned, you can try reducing the Rendering Quality as well. Perhaps even the Draft or Medium mode would be of better use if you’re not placing down much or any lighting at all in darker areas.
