Hello everyone,
I recently started working on a MacBook Pro M4 Max 64. When using Enscape on SketchUp, the live preview is very blurry, which is quite disturbing. However, when rendering, the exported image is sharp. The issue only occurs in the live preview.
I tried checking and unchecking the focal setting, but nothing changes.
Thank you in advance for your help and feedback.
Hi @John_KL
We have seen it once too when m4 max just arrived in the office. It was not due to lower (for any reason) frame rate - viewport was just a bit blurred, while screenshots were just fine. While looking into the issue a couple of days later we could not reproduce it any more.
Just to make sure it is the same issue - please try disabling auto upsampling and resolution in the general settings and see it it helps. If so, there might be something which slows down Enscape and lower resolution rendering is triggered.
