Bucket noises when using Vray Environment Fog
When using VrayEnvironmentFog we witnessed strange artifacts which show bucket areas.
It’s not the GI as far as I can see it … And we are not within the gizmos for the fog even …
Best, Peter,
xoio
Edit: I just tried in progressive mode, it’s still there …
Is there some kind of geometry there? Are you using a gizmo for the fog?
Yes, I use a HiPoly-Ball, which is modelled to simulate some Cloudshape … and a noise-fractal in the density to break up the cloudshape. The Geometry is set to not renderable in the properties …
The scene is fairly small, if you want I can send it over … ?
Cheers, Peter
Edit: Attached Screenshot:
Yes please - send the scene either to support@chaosgroup.com or attach it here in the forums.
Thank you very much in advance.
