Bug with V-Ray Sun and Clouds
Hi There,
I’ve discovered a bug with the new cloud system, but first let me explain our scene setup:
In order to have multiple Daylight Systems or just V-Ray Suns within the same scene working properly, historically we have done the following - First of all in V-Ray’s Global Switches render settings ‘Hidden Lights’ is Unticked
Each V-Ray Sun or Daylight System is placed on it’s own unique layer along with a V-Ray Dome Light that has a V-Ray Sky in it’s texture slot. This sky texture is manually connected to the corresponding V-Ray Sun object.
We then use Scene States to turn on or off whichever lighting layer we’d like to be active for a particular camera, and tie this in to our custom rendering script. Thus we can have as many unique V-Ray Sun setups within a single scene as we like, very useful when you have 25 verified views each taken at a different time of the day.
This system has worked for us going back as far as we can remember, and here’s where we run into a new bug in V-Ray 6 and Max 2023. Ticking the Clouds button with the V-Ray sun does nothing. The lighting and layer switching still works exactly as expected, but no clouds show up at all.
Could you look into this please? Best regards, Bill
Here’s a post which suggests a fix may be upcoming, although it does work in a fiddly way right now it’s probably not helpful in your scenario.
https://forums.chaos.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-problems/1156496-v-ray-6-clouds-on-feature-problems
Since the Cloud settings are not yet implemented in the VRaySky node, the clouds will disappear when connected to a Sun (this will be fixed soon). For now, set your scene sets by simply enabling the correct Sun for the specific frame.
Cloud to VRaySky nodes not implemented yet? (Do I have to request it through the Ideas Portal?)
There are requests to connect VRaySky to Dome to switch between multiple Cloud settings and use it for LightMix.
Best you log it in the Portal.
I created it
https://chaosvray.ideas.aha.io/ideas/VRAYMAX-I-102
(It’s too much hassle, so please implement an AI that automatically collects ideas from forum posts.)
By the way, I’m talking about “clouds in the sky”, not Chaos Cloud.
Hi, the bug is still present. Once it is fixed, you should be able to link a sun to a skymap that is attached to a dome light. The idea will not be published for now, as it requires first the bug to be removed. The issue is registered under VMAX-12417.
It’s only been 2,5 years…First report was in 07/2022: Clouds not showing - V-Ray for 3ds Max :: Issues - Chaos Forum
