V-ray 6 clouds on feature problems
Hello forum,
I’m experiencing a problem with this new “clouds” feature of Vray 6. If i add a new vray sun AND automatically add a sky in the environment when i get prompted, all works fine.
However if i don’t add an environment sky directly from the prompt, and i try to add the sun first, and add the sky later, or if i have multiple different suns with their own perspective skies and i switch between them,
the cloud feature doesn’t work in the sky background (i can only see a whee bit of cloud in front of the Sun only).
Anyone knows if this is a bug, or i am doing something wrong?
Seems to work fine for me, although it is a little odd.
You can try this file…I added the sky after the two suns.
You can run the IPR and switch between them, turning one on and the other off.
The unusual thing is that if they are both off then the clouds still show but the lighting is still there and comes (without shadows but sun visible) from the last sun that was created.
You can see this if you add a 3rd sun in the scene.
It will update and switch properly…it’s just weird :slight_smile:
MULTI SUN CLOUDS.rar (50.8 KB)
A multiple sun system also works for me. However, if more than one VRaySun with clouds is active, the last created is rendered (this will be fixed when we add the Cloud options to the VRaySky node, so you can choose). I managed to reproduce what @fixeighted was referring to. I’ll ask around if it’s expected.
Having the vraysky in environment with multiple suns works really well while turning off each one, but, linking in a Vraydome has a little trouble to identify the changes, you need to turn off anf on the dome or make any adjustment to the map in order to change the sky.
I atacch the Scene and a Video about this.
10 Multi VraySun Clouds.zip (56.2 KB)
Thanks for the report. I’ve logged the issue (internal bug-tracker id: VMAX-14011) for dev investigation.
Thanks Hermit, a “solution” that I didnt show was to create 1 dome per sun, that way, the sky changes inmediately
Hi
I want to continue with this topic because I think theres something that needs to be fixed while using Lightmix in Vray 7.
If I use multiple suns + skies, Lightmix has trouble to display the skies while having all turned on.
Heres the workaround:
Every sky map is attached to a Vray dome, heres how I can use each sky with its sun.
If I attach the sun to the sky node, every sky is recognized in lightmix, but it doesnt display clouds, you can only “see them” in the sun.
If I dont attach the sun to the sky node, only 1 sky (the last one created) is recognized in Lightmix.
I attach a sample scene and a video.
10 Multi VraySun Clouds.zip (64.1 KB)
Multi VraySun Clouds LightMix.zip (1.22 MB)
I presume the kernel of the issue is the same, but I’ve logged this issue too (̶i̶n̶t̶e̶r̶n̶a̶l̶ ̶t̶r̶a̶c̶k̶e̶r̶ ̶i̶d̶:̶ ̶V̶M̶A̶X̶-̶1̶4̶8̶9̶8̶ ̶)̶. Your goal is to have multiple variations of the Sun/Sky node rendered in one pass, the visibility of which you control via LightMix, correct?
You’re in luck. I just found we already had this issue logged (internal tracker ID: VMAX-12417), and a commit was made for its fix yesterday. I just tested it with the latest internal builds, and it works as expected. It will be picked for the next release.
@hermit.crab big thanks, for the latest internal build you mean latest nightly? or that will be the “next release”
I meant the nightly builds, yes.
Installed vray 7 update 1 and… :frowning: it hasnt been fixed… hopely soon
This update was a technical one without many bug fixes. It will surely be picked for the next.
Big thanks!!!
4 years from this, theres no solution yet? is quite a common problem I would say.
As I recall its already solved in updated 2.
