Vray 6 clouds not rendering
Hi
I tried the Beta for VRay 6 for Max 2023 and found the clouds did not render at all, tried Vray Sun, daylight system nothing.
Got busy so forgot about playing with VRay 6, came back to it and noticed the Beta didn’t work any more, soooooooooo downloaded the 30 day trial … still no clouds. Scene image below, simple cube on a plane with a VRay sky, sunlight and NO clouds.
Any ideas.
Spike
Just found the post add VRaySky after the sun and it worked … until I replaced sunlight with a daylight system (use them all the time, international projects), then I had to delete the VraySky, insert another VRaySky (after the creation of the daylight system) and it worked … until I specified a sun node to the daylight system … after un-ticking the sun node, it works again … cannot upgrade to something this flaky.
It’s not very hard to setup a VraySun with a Daylight system.
- Create Daylight System
- Create VraySun & Sky
- Align Sun and his target to the Daylight system and link Sun to Daylight
- Disable Daylight system
- Enable clouds in VraySun
- Save this for later use
