C4d Alpha RC1
Hi. I installed the C4d Alpha RC1 but I can’t locate the corona plugin…
Well it is missing, but it is missing from a different place now :smiley: See attached image as to what you should see if the install has gone correctly.
To fix, you could try the Unpack option from the installer and move the corona folder to the plugins folder under your C4D install.
Or it looks like your top toolbar may have more icons, from the right pointing arrow - the Corona menu may be in there after the other installed items on that menu bar.
