Add volumetrics to your scene such as smoke, fire, water, clouds etc in the form of a .vdb file (fire/smoke), or just an object using a Corona Volume Material (smoke/fog) or Corona Physical Material with refraction and some volumetric effects enabled (water/other liquids/glass). You can then place your camera inside the volume and it will render fine.
Optionally, you can enable ‘‘Camera Physical Size’’ in the Corona Camera. This lets you place your camera at the border of two or more volumes and see the volumetric effects as expected (an example of this is partially submerging a camera so that you can see what is outside of the water and underwater).
Great that it’s possible now.
One thing since it shows nice in your last image - it seems sun is not dimmed correctly when it’s behind a thick volume. Even if the volume is thick enough to blocks any light the sun disc will still remain visible. Hopefully this can be resolved, it’s certainly an undesired effect in some situations.
Not sure if this is the best thread for this, but I’m discovering that the “camera physical size” parameter of a coronacamera is always oriented the same way regardless of rotation of camera (with or without target), meaning that if you have your camera for example pointing at 45 degrees instead of directly up, down, left or right, it will clip the apex of the “box” that it lives within.
This is with 11HF2. Is this fixed in 12.x? Or is there a workaround so that it properly follows the orientation of the camera?
Great news! Thanks for confirming. Looking forward to updating to C12.2. Just waiting for all the usual suspects to update to support it first and we can then test this.
Glad to see this align-with-camera is now working. But one issue remains that we ideally need the “camera” to be a rectangular cuboid i.e. ability to separately control it’s 3 x dimensions. Because right now if you want to do this half-in-water effect you’re forced to determine it with a cube, so if you want a close cut (say 10cm away from camera) it means you can still see the far faces of the cube in the render causing artifacts. We need to be able to make the width and height separate from the depth basically. As of right now I’m still having to overcome this by using a custom invisible box that I use as a coronaslicematerial to cut out of the water. Sorry no preview to share as it’s under NDA.
Given the vast customization of the slicing volume with slicer material (custom shape, linking to camera, animating if needed), I don’t think it is worth adding the same functionality (which will clutter the UI for a simple thing) into camera. Camera physical volume is intended for the general-use-case quick medium cuts aligned with the camera. I believe it does the same thing as slicer material under the hood, so good thinking on the workaround
I understand where you’re coming from, but in my experience this tool as it stands isn’t usable unless your FOV is so narrow that you don’t see the “cage”. Not sure what the point of the tool is if the only way to use it properly is to actually not use it at all and do it all manually using a slicer. Wouldn’t it make more sense to fix the current implementation so it can achieve the desired result? As you say, that tool has basically one single purpose/use-case, so it makes sense to me to make it work for that use case without such an obvious limitation. I’m sure this could be achieved without bloating the UI. After all there is already a section there for it in the camera.
hey team - im having trouble doing an inside water volume. I have a pool shot and i want to do that effect of half in and half out the water - does anyone have or know of a guide that exists?
i guess what im struggling with is, is the best method to do a PLANE as the water material or does the water geometry need to be a enclosed area (ie rectangle or box)?
It would now need to be enclosed geometry, which was always safest. The new check introduced to remove the “I accidentally ended up with the camera thinking it’s inside a volume” is to check in TWO perpendicular directions to ensure that the camera really is inside a volume, so without a face painted with the water material in both directions, the camera will assume it is not inside a volume (thus preventing the fact that otherwise the volume from a plane was in effect infinite and you could end up “entering the volume” unexpectedly).
