Camera navigation like standard 3sMax camera => Ability to orbit, pan and move without having to change the tool
I was always wondering, why the Vray camera has such arduous unintuitive navigation.
I don’t know any other software that forces you to switch between tools (orbit/pan/move…) in order to navigate your view.
How about giving the Vray camera just the same navigation as the standard 3dsMax camera has? At least optional…
What do you mean?
EDIT: I ask as there are absolutely no differences between camera controls.
What you describe only ever happens with camera-less viewports (i.e. user/persperctive).
Hm, can you navigate a vray-camera with same hotkeys like 3dsMax cameras? (if you press „P“ the perspective camera, this is a camera that works as expected)
I have to use the camera tools in the lower left.
If there is a difference, maybe because I have Maya navigation enabled as default?
a perspective view is not a perspective camera, in max, unlike in maya.
It’s just a view type (You can create a camera from it, however, with ctrl+c).
The rest of the controls for the camera are identical. In fact, the max physical camera *is* the v-ray physical camera, at least up until the point the code was given to Autodesk.
So it means you have the same navigation (with need to change between orbit an dolly camera tool)
and it can‘t be changed?
So 3dsMax has this horrible cumbersome navigation deep implemented and that‘s why vray has it, too?
(I just would like to understand, which is the source of the problem)
Nah it’s easy; just map keys/combos to the functions. I always hated those teeny weeny icons. Use shortcuts for everything to make your life easier :slight_smile:
Thanks, I have assigned hotkeys. But I don’t feel comfortable with it… (maybe because I’m many more years used to Maya & other software, and so Max is for me the „alien“ ;))
maybe walkthrough navigation is what you’re looking for? fpp video game like.
im just using max, coming from maya and having to use dolly and orbit in an untargeted camera feels really bad and cumbersome…why the controls would be different to perspective camera is just odd :slight_smile:
So just to confirm so i stop feeling like im going mad… in perspective mode, you can zoom, orbit etc with mouse, mouse wheel and alt keys… but as soon as you change to a camera, these are disabled and i have to click different buttons or shortcuts?
haha. true. if you put it like that it is quite insane in max.
with untargeted cam I use walktrough mode (up arrow key should be the shortcut) with x and y rotation locked (archviz)
edit: x and z I guess, (tilt-shift lens)
i tried the walkthough and the camera started moving on its own and wouldnt stop :slight_smile:
maybe the speed needs to be adjusted with + and -.
Losing my mind using these little icons here as well, @francomanko BeneZ What shortcuts do you guys use for this now? or did you find a solution?
i just ended up setting hotkeys for the zoom tool and pan camera mode .
Couldnt get a decent way for my wacom to zoom like in maya but stuck with these settings. Not ideal by a long way and coming back into maya felt like a cooling breeze on my angry red ‘3dsmax’ face :wink:
p.s.: these work on Perspective views. Set the view up as you please, select the camera, press ctrl+c to line it up with the persp view.
Only if this perspective navigation worked for camera navigation, like why would would it be different
What I usually do is have a test camera for my look-dev which I can navigate freely in the IPR, it is just so awkward in 3Ds Max out of box
Maya, C4D, Houdini and Modo all can do same perpective navigation with cameras using Mouse and keyboard.. out of box
I’m gonna map Zoom and Orbit to hotkeys like what others did
They’re different because they have very different functionalities, historically and within the Max way of working.
With a persp view you can always rotate around selection center, f.e., or quickly zoom to selection.
Doing so within a cam view would have to move the target, or the camera, respectively, and that could be problematic (Max also has an auto-key function. Do the above away from frame 0, with the autokey active, and you got yourself an animated camera.).
If one locked the camera, as it’s wise to do once it’s approved, then the above wouldn’t work at all, and the camera locks are hidden away (unlike, f.e. in houdini.).
The same would apply to shortcuts.
As a side note: ctrl+r, ctrl+p are -at least in max 2022- the universal shortcuts for pan and rotate, wether the view is a camera or a perspective.
You may have to add those for Truck and Zoom (Called “Field-Of-View”), however.
For what it’s worth, i personally can’t stand that a camera should move like a perspective view, but of course i would, coming from decades of Max.
Thanks for your input Lele :slight_smile:
Ctrl r and Ctrl P should do the job, then now I assigned Ctrl T to Dolly mode for zoom. I will get used to these shortcuts
I use Auto-key function a lot similar to C4D and Houdini
Slowly getting the hang of this DCC
