Cannot render animation, segfault
Probably not much use writing here, but here it goes anyway.
Vray on Houdini 21 on Mac.
1-frame renders pass.
Animation render segfaults on the second frame.
It is just a rotating cube scene, just for a damn test., my real scene refuses to render animation anyway.
Latest official vray release, rendering at the command line using the same houdini vray, not standalone, as we had to do for years, because standalone did not support houdini.
Ok, lets assume the problem is that I use the wrong renderer. Downloaded standalone, as help recommends.
It appears to be stale as hell: the vray for houdini uses the cloud licensing, standalone asks me to install license server.
Guys, what is going on?
V-Ray Standalone crashlog on mac attached.
segfault2.zip (24.2 KB)
The root of the problem seems to be in the denoiser node. Obviously there haven’t been macs with nvidia or intel for quite some time now, and the default vray also seems not to be able reliably to fallback to CPU. But the bug seems quite random, so I would not bet my life on this.
