Hello;
I just downloaded Vantage wich seems very interresting. Thing is that i can’t initiate it in 3DS Max. I use 3DS Max english version, i installed Vantage with the live link to Max. When i go in customize inteface → toolbars i can’t find the Chaos Vantage in the categories of Main UI or anywhere else
Vantage standalone works fine.
Thanks for help
Daniel
OK i found the trick. Install Vantage under an admin session, switch to my user session, copy the scripts from the admin apdata folder to the user appadata folder and there it works.
Daniel
Hey, great you managed to solve the problem yourself!
For clarification by ‘admin sessions’ do you mean your user account has no admin rights or you did “Run as administrator” on the installer?
