Cant render animation in new Vantage 2.1
I have a scene where I test Vantage for some time without any problem. After update Vantage to 2.1 viewport rendering is fine but when I try to render animation nothing happen. Rendering stills is again without any problem. Now I cant render animation, where is a problem?
Thank you.
Hi, thanks for posting. Please check this thread. This is a bug with the 2.1 but it is being pushed for quick fix. We will let you know when there is a working publicly available build.
I am using live link. Hope fix will be there soon, thanks.
I am posting the workaround again in case you’ve missed it in the other thread:
there is a workaround for it:
  1. Save a .vantage file so that the cameras are saved;
  2. Export a .vrscene and load it in Vantage;
  3. Load the vantage file saved in step 1 - the cameras and animation setup should load properly
  4. Render out the camera sequence
Yeah, I saw that. But now I dont export vrscene, just using live link.
How it looks about fixing this issue?
We plan to release a patch on Tuesday.
Fuuny…I thought it was me…ran a test live link animation and it never rendered. Good to know it’s an actual bug and not my error.
Great, thank you.
The patch is released, 2.1.1. Can you confirm the issue is resolved?
yes, its working now, great, thank you!
try to render just as JPG sequence and not as mp4.
