We’ve got a problem that we can’t render the last frame in Vantage. We’re exported the .vrsence with a specific “frame range” from 3DS MAX.
It’s always stopped to render before the last frame. Any idea about that? Our Vantage version is 1.4.2
We fixed a bug with this description in 1.4.2, so it is strange that you’re having such an issue. Are you rendering the sequence in Vantage at the same framerate it had in Max?
The screenshot also shows the little red and green “trimming” triangles on the timeline are set toward the end of the timeline - could this be causing it? What if you didn’t set them, so they stay at the start/end of the timeline?
