CAN'T RENDER
Sketchup 7, VRay 1.5
I can’t render models made using version 1.05 since I’ve upgraded to 1.5. Debugging options DO NOT help and so does copying and pasting the model from the old file to a new file.
I click the render button, it freezes for a moment, like it would before a render, then nothing happens. it just returns to normal. Like I haven’t even told it to render. Frame buffer does not come up.
I’m considering changing back to the old VRay because if I can’t render theres not much use to the new version obviously.
I’ve seen alot of other people having this problem and, well, haven’t found a solution yet. Do something about this guys.
Re: CAN’T RENDER
You mean 1.44.66 - right?
There are several issues known to the developers that causes the render not to start. Could be a material - could be a light made into a component.
Check out the stickies in this Bug Section:
Understanding VfS Error Log
Where is the VfS error log?
