Changing render if Corona is set to default causes 3ds max 2023 to crash.
I set corona to default when max start. But, in max 2023 that causes the program to crash if I were to change render after max has started.
I can open a scene which uses another renderer like scanline, but changing in the render setup from Corona makes 3ds max crash.
This is already fixed in Corona 9 https://forum.corona-renderer.com/ max 2023.2 crashing when closing render setup dialog
