Chaos Corona 13 for 3ds Max - Daily Builds Changelog
Please check this article covering the risks of using daily builds: Daily Builds FAQ
If you are familiar with the daily builds and know how to use them, download the newest one here:
chaos-corona-13-3dsmax-daily-2024-07-30.exe
Note: The following will be released as a hotfix for v12 soon.
User-Facing Improvements
  • Disable history autosaving for sequences and for slaves during distributed rendering. This is to avoid poping a blocking confirmation dialog about history item deletion when the user is likely not around.
  • Added bakeIthLightMix function to MAXScript to allow baking parameters of specific light mix element.
Bugfixes
  • Fixed issue where several of the new parameters (Bloom&Glare compute after rendering, IR resolution lock, VFB history settings) could not be accessed via maxscript.
  • Fixed issue where interactive rendering would disable denoising blending in VFB2 for the following production rendering.
  • Fixed errors when switching color management mode while IR is running.
  • Fixed crash when using “scene-linear Rec.709-sRGB” space in OCIO mode, when the scene contains dispersion.
  • Fixed pick and region mode turning off after IR is started.
  • Removed accessing data objects in TileMap during rendering.
  • Fixed crash in pattern occurring when using pattern object with degenerate triangles.
  • Fixed issue where changing aperture parameters did not refresh VFB2.
  • Fixed rare crash while switching from zoomed-in production rendering to interactive rendering.
  • Light select names in VFB2 now update after renaming and re-rendering, also after switching from Edit CXR.
  • Fixed issue where VFB2 could crash when someone deletes history item without using VFB2 controls.
  • Fixed issue where light mix was reset when docked IR was started.
  • Fixed dialog resizing on render start to adjust its size to contain as much of rendered image as possible.
  • Fixed locked IR resolution second dimension value being wrong on entering (due to upscaling factor).
  • Fixed issue where VFB2 was not updated when render stamp was changed from MaxScript.
  • Fixed issue in Corona Image Editor where tonemapping in rare cases could look different than tonemapping in Corona VFB.
  • Improved frames per second in docked VFB.
  • Fixed issue where NVidia denoiser was not applied during production rendering. Added missing refresh of VFB when denoising is done.
  • Fixed issue where IR was restarted while VFB dialog size was changed even though its resolution should have remained unchanged.
  • Fixed copying of colors between different color swatches in Lightmix tab.
  • Fixed issue where 3ds Max would freeze when history item deletion dialog is shown after rendering finishes.
  • Fixed saving of CXRs for light mix elements.
  • Fixed bad_optional_access error when opening Render setup dialog during rendering.
  • Light mix layers can now be toggled by clicking on the entry widget, not just the checkbox, same as in the old VFB.
  • GammaCorrectionOperator present in .conf files is now handled correctly - the operator is removed from the pipeline and the rest is loaded correctly.
  • Fixed issue where real world mapping was not applied on some materials imported from Cosmos.
  • “Show VFB” now also raises the Vfb2.0 above other 3dsMax’s dialogs (as Vfb1.0 did).
  • Fixed IR restarting/changing appearance after Render Setup dialog is open.
  • Fixed issue where VFB would show when updating scene with docked IR running.
  • Fixed color management update when loading a Corona scene with other renderer being set as default.
  • Fixed issue where old V-ray materials could not be rendered/converted.
  • Fixed incorrect position/scale of VFB2 after restore from previous session on multi dpi monitor setups.
  • Fixed issue where scatter edge trimming would in some cases incorrectly trim instances.
  • Fix issue where minimized VFB stays hidden when rendering starts.
  • Fix of not updating VFB2.0 when option “Lock 3ds Max during render” is set.
chaos-corona-13-3dsmax-daily-2024-10-10.exe
NOTE: The installer has new digital signature, which may trigger warning when run. This is expected and fine.
Major User-Facing Improvements
  • Added Depth of field range indicator for 3ds Max Viewport, when Corona Camera is selected.
  • Extended CoronaBitmap about togglable aspect ratio lock button + added ‘Fit to bitmap’ button. The second one is available when Real World Scale is on and lock is not active.
  • Caustics improvements: - - More photons are now delivered to caustics in large/complex scenes.
  • Added max photon repeat parameter into advanced settings that influences noise of caustics.
  • Added intensity multipliers (surface and volume) for caustics.
  • Added the option to load multiple CXRs into VFB history at once.
  • Added an improved algorithm for white-balance computation. To ensure existing scenes render as before, they will load using the “Legacy White Balance” tone mapping parameter.
  • Removed the Corona Material Library component from Corona installer. If you do not have it installed already, a download button will be shown on opening the Corona Material Library.
  • Added a decal arrow pointing in the decal projection direction.
  • Vfb2.0 - Shows correct render stamp when loading or comparing images.
Bugfixes
  • Fixed changing of “Locked IR resolution” when rendering with docked interactive.
  • Fixed issue where OCIO would convert everything to black when alpha is NAN.
  • Show image comparison splitter at the center even when zoomed in + draw also overlay A/B when zoomed in.
  • Interactive rendering restarts are now faster when using Caustics solver.
  • Small behavior fixes of the button used to select node for fitting PatternMod crop box.
  • Fixed issue where caustics did not work correctly with Foam or Slicers.
  • Fixed issue where clicking on Save in VFB would not save the currently displayed image, but the rendered image instead.
  • Fixed issue where saving values over 1 to PNG/JPG with OCIO would give incorrect results.
  • Fixed issues with decal/media and heterogeneous media when material-based medium resolving is used.
  • Fixed issue where animated texmaps would in some cases render without animation.
  • Fixed issue when a selection of non-defined map channel could affect scatter distribution.
  • Fixed issues with value precision sensitivity of scattering in some scenarios and improved consistency of scattering results across various scatter integrations.
chaos-corona-13-3dsmax-daily-2024-10-23.exe
  • Chaos Installer is now used instead of Corona legacy installer. - Command line arguments were changed. You can use -auto instead of -acceptEulaAndInstall. For more command line arguments use -help.
    • Unpack is no longer option in installer. Can be done by command prompt --unpackInstall=dir. E.g. --unpackInstall=“C:\User\Corona\Unpack”.
    • Note: Requires SSE 4.2, released in 2008 for Intel and 2011 for AMD, so any machine newer than 13 years old should be unaffected.
      This would be around one tenth of one percent of users at our estimate, and some of those may be using an older Corona version anyway since Corona itself needs SSE 4.1 already.
  • Added a Separate IR button instead of the dropdown menu option.
  • Collaboration now disables 3ds max hotkeys only when text is edited.
  • VFB2.0 - Place new history items at the top of history instead of at the bottom.
  • Added support for ForestPack Ivy Generator.
Bugfixes
  • Fixed issue where showing VRayMtl in material editor without VRay installed leads to crash when Corona is active renderer.
  • Fixed issue where Caustics solver could cause NaNs when used in volumes.
  • Fixed issue where camera name in Tone Mapping disappears after editing history item and rendering again.
  • OCIO config path from the environment variable “OCIO” is used only when the respective mode is selected in Color Management settings.
  • Fixed not being able to maximize the VFB while IR was running as it re-adjusted its size.
  • Fixed issue where debug.log file is created in 3ds Max project folder.
chaos-corona-13-3dsmax-daily-2024-11-04.exe
  • Upscaling - Added option to upscale rendering for both interactive and production rendering:
    Upscaling is intended for the quicker rendering of draft renders, including animation.
    For both IR and Production rendering, it halves the render resolution (width/2 x height/2) and then upscales to the set resolution.
  • Added automatic exposure & white balance into postprocessing.
  • Added initial support for Vantage Live Link.
  • Added option to system settings to disable overwrite confirmation dialog when using history autosave.
  • Added Unpack button to the installer which performs the unpack installation.
  • Fit to bitmap in Corona Bitmap now works also in non-real world scale mode.
Bugfixes
  • Fixed issue where auto-saving animations into history often resulted in black history snapshots.
  • Fixed issue where material library would not be downloaded through the material library dialog when the user did not have permission to modify Corona installation folder.
  • Fixed incorrect order of render elements in case Rest render element was not the last one.
  • Fixed crash when opening Login window in Cosmos browser.
  • Fixed issue where sometimes the sun and environment lights were accidentally calculated as being inside a non-global volume during caustics computations.
  • Fixed 3ds Max hotkeys being wrongly reenabled after clicking from Cosmos to another Corona spinbox.
  • Fixed issue where “Need help setting up licensing?” link in installer leads to Vantage installation page.
  • LUT path is no longer converted from local to UNC after arbitrary UI operations.
  • Fixed animated camera unexpectedly changing position when switching target on and off.
Corona 12 Update 1 (not hotfix) will be released before Corona 13, below is the first Release Candidate of Corona 12 Update 1.
chaos-corona-12-update-1-3dsmax-RC1.exe
  • Added option for the camera physical box to follow camera transformations and tilt.
  • Improved decal arrow sizing, based on the decal box size.
  • When exporting to Vantage, Corona exports to a running Vantage application instead of starting a new one. When Vantage is not installed, error is shown to the user.
  • Added new Legal Agreements dialog, which is shown only after “–auto” installation (when the eula/privacy policy is not shown).
Bugfixes
  • Paths to assets used in Corona Material Library downloaded from Cosmos are no longer converted from mapped drives to UNC paths.
  • Fixed Memory Report dialog preventing render from completing, it is closed automatically for render to finish.
  • Fixed issues in Caustics solver when Camera physical size is enabled - specifically incorrectly shaded caustics and shadows casted by the camera box.
  • Fixed Bloom&Glare occasional incorrect computation when Auto Adjustment is on.
  • Disable denoising UI in VFB when upscaling is ON, because upscaling forces denoising ON.
  • Fixed issue where interactive rendering in docked VFB would reduce user interface responsiveness when upscaling and sharpenning/blurring were enabled.
  • Fixed issue where Cosmos lights were imported with wrong units.
  • Fixed Scatter not updating correctly. Scatter is now also uninstalled with Corona, but only if V-Ray of corresponding version is not found.
  • Fixed Bloom&Glare missing when saving multiple elements with B&G.
  • Fixed issue where fitting decal and then changing the size with locked aspect ratio would result in incorrect decal aspect ratio.
  • Uninstallation should no longer fail when some directory cannot be removed because it is still not empty during uninstall (e.g. due to some additional added file).
  • Fixed computing of curves operator histogram - histogram now updates during rendering and is computed from editted item as well, not always from the main render.
  • Fixed issue where some OSL maps (e.g. those using user-defined attributes) were not working properly.
This daily build is planned to be released as Corona 12 Update 1 Hotfix 1 soon, if no issues are found.
chaos-corona-13-3dsmax-daily-2025-01-10.exe
Bugfixes
  • Chaos installer advanced install - “continue” button is now disabled when no component is selected.
  • 3ds Max shortcuts are now disabled for Cosmos sign-in dialog.
  • Fixed issue where ForestPack IVY was not animated in production rendering.
  • Fixed issue where ForestPack was no longer scattering Corona light sources.
  • Fixed issue where light sources scattered with ForestPack were all in the same light mix selection.
  • Improved overall responsiveness of UI when rendering with Corona.
  • Scanned Material: - Fixed “Advanced” dialog not being hidden when license is not available.
    • Fixed loading of material when relative paths are stored (Preference Settings > Files > Convert local file paths to Relative).
    • License is not obtained immediately after creating the scanned material anymore. It is obtained only when UI is displayed or when writing new parameter values.
chaos-corona-13-3dsmax-daily-2025-02-28.exe
User-facing improvements
  • Implemented differential ray filtering. This improves texture filtering seen through reflection/refraction, and directly visible textures in fisheye, spherical and alike projection cameras.
    Enabled by default in new scenes, old scenes have it OFF and should show a message for switching to new filtering.
  • Optimized parsing in interactive rendering when changing time - only objects/textures that have animation will be re-parsed.
  • Significantly improved DOF (Depth of Field) solver. It should now work well in all supported cases (perspective camera with no VR and no distortions).
  • VFB scrollbars are now brighter for better visibility.
  • VFB history item thumbnails now update when edited.
  • Enabled toggling of Tone mapping operators by clicking on their label (but only if they are not collapsible, in that case those are collapsed/expanded as before).
  • Added ‘Only unsupported’ option to Material override to override only unsupported materials.
  • LightMix in VFB2: Toolbar and source element label are locked and only the layers are scrolled.
  • Curves histogram tooltip displays “Histogram type” instead of “Histogram kind”.
  • Added label saying where to find histogram controls to Curve editor in pop out Tone mapping menu.
  • Added Global Volume override for CoronaCamera.
  • Added option to reset all curves.
  • Added shortcut to start/stop Vantage Live Link to Corona toolbar.
  • Changed installation root from ‘C:\Program Files\Corona’ to ‘C:\Program Files\Chaos\Corona’.
  • Added automatic virtual tours (auto panorama recognition, auto hotspot generation) support for images uploaded to Chaos Collaboration.
  • Added support for importing multiple Cosmos assets at once.
  • VFB - Region draw is enabled when editing CXR, but only when edited CXR is of the same size as current/last rendering, which is necessary for resume render.
  • Added progress bar showing Vantage upload progress. Scene upload to the Vantage can be cancelled now.
  • Added missing tooltips to VFB’s Auto adjustment properties.
  • Added dialog with Chaos account information (opened from System > About Chaos Corona/Licensing).
  • Added mix alpha option to CoronaMix map.
  • Chaos Collaboration - Image uploaded from history item keeps the item’s name.
Bug fixes
  • Fixed color management warnings being displayed even when Corona is not the active renderer.
  • Fixed lightmix looking different than beauty when OCIO color management is on.
  • Fixed highlight of checkboxes in Tone Mapping and Lightmix VFB tabs.
  • Fixed issue where adaptivity and denoising was incorrectly computed when using DOF solver.
  • Removed clamping for negative values in CoronaColorCorrect texture when not needed.
  • Fixed missing update of IR/LiveLink when new objects are imported into 3ds Max.
  • Fixed ScannedMtl triplanar mapping moving with the camera.
  • Fixed differences in Beauty vs Lightmix render channel for complex materials.
  • Fixed crash when rendering with geometry motion blur enabled.
  • Fix for not working sub-surface scattering on objects with decals seen in reflection.
  • ScannedMtl: - Fixed file not rendering/displaying in UI even when it is found in 3ds Max Asset Tracker
    • Fixed “Adjust UV tiling” button being incorrectly enabled when Triplanar mapping is enabled at the same time
  • Fixed issue where translucency settings were not considered in thin mode during conversion from V-Ray material.
  • Fixed issue where using reflection/refraction override together with black environment could lead to incorrect results in some rare cases.
  • Fixed issue where NAN in Corona Color Texture would propagate further.
chaos-corona-13-3dsmax-daily-2025-03-28.exe
  • Added the possibility to import Scanned materials from Cosmos.
  • Added the possibility to apply Bloom&Glare on the alpha render element.
  • Detect 3ds Max environment effects and provide an option to delete them.
  • Added support for Max 2026.
Bugfixes
  • Explicitly update VFB after render stamp is toggled.
  • Fixed issue where the light mix context menu in VFB was not working when right-clicking on the light select names.
  • Tonemapping errors are no longer shown when doing live link to Vantage.
  • Fixed missing MaxScript names for parameters in TileMap, VrScans material, CoronaCamera, Curvature map, Chaos Scatter, Corona Pattern.
  • Fixed auto adjustment result being influenced by pixels excluded from rendering.
  • Preview of Chaos Scans with triplanar mapping enabled now shows average texture color.
  • Fixed issue where render could be aborted when running IR and rendering bitmap in the material editor at the same time.
  • Corona Curvature map now correctly works for objects with intersecting elements/volumes.
  • Fixed files uploaded from VFB history having wrong metadata for automatic virtual tour generation in Chaos Collaboration.
  • Added new LUTs made by Iraban Dutta.
  • In quiet mode (batch, command line rendering) take into account whether “Show overwrite confirmation” is enabled. If not, allow VFB history autosaving.
  • Fixed issue where light mix was not correctly exported to standalone.
  • Chaos Collaboration - Fixed uploaded images having incorrect gamma in Gamma color management workflow.
  • Improved the VFB refresh at the start of the production rendering.
  • Increase Corona Light viewport performance by not previewing hidden lights.
  • Fix image gamma loaded in CoronaBitmap to be 1.0 when using OCIO workflow. This makes CoronaBitmap give the same results as Max bitmap.
Regression bugfixes
  • Fix for the change in appearance in Corona Mix Map in sRGB mode.
  • Fixed preservation of legacy mode in Curvature Map.
Below is first release candidate for Corona 12 Update 2.
From now on daily builds, release candidates and final releases will also be available in your Chaos account’s downloads page.
Select “Go to other versions”, instead of “Official release” pick “Preview” and you should be able to see the latest download.
GDrive link as before:
chaos-corona-12-update-2-3dsmax-rc1.exe
  • Added checkbox for clamping/enable negative values. LUTs and Curves now pass channels with negative values and modify channels with nonnegative values.
  • Added support of Intel Denoiser for Blackwell (NVIDIA 50-series) GPUs.
Bugfixes
  • Fixed slowdown when Lightmix channel is shown in VFB - up to 10x slower than beauty on some PCs.
  • Fixed issue where applying decal on a glass object could lead to wrong refraction.
  • Fixed issue where Corona Pattern had holes in Orthographic projection.
  • Fixed missing lut/ies assets during rendering in case AssetManager can resolve them.
  • Fixed Vantage live link updates when deleting after moving camera/changing sun parameter.
  • Fixed issue where translucency settings were not considered in thin mode during conversion from V-Ray material. Added condition for use of SSS color
  • Fixed DPI scaling of licensing dialog and legal agreement dialog. Fixed wrong telemetry information link and host application name in legal agreement dialog.
  • Fixes issue where interactive rendering with Intel denoising was saved without denoising into history.
  • Added legacy mode for displaying the bitmaps in OCIO as in v12 Update 1. Fixed textures from Cosmos loaded with wrong gamma.
This daily build contains fixes intended for upcoming Hotfix for Corona 12 Update 2.
chaos-corona-13-3dsmax-daily-2025-05-07.exe
  • Simplified trial obtaining process.
Bugfixes
  • Fixed crash on Max start for old CPUs without AVX support.
  • Fixed a bug where material drag&drop from Cosmos would not work in Max 2025 and newer.
  • Fixed issue where Scan materials imported from Cosmos were blank if the user did not have Scans license.
  • Fixed issue with the slow import of the Scan materials from Cosmos.
  • Fixed issue where Rotate and Select&Place tools would behave erratically during IR.
  • Fixed issue where aspect ratio lock was not working in Corona Bitmap.
chaos-corona-13-3dsmax-daily-2025-05-21.exe
  • Added new Toon material.
  • Added new Corona Outline Material. It is possible to setup outline material globally or per object/material.
  • Added thin film to the Corona physical material. This allows the users to create materials with iridescence (e.g. soap bubble).
  • Added firefly filter that cleans fireflies during the whole rendering, both interactive and production.
  • Added .vrscene import and its icon in Corona toolbar, which requires VRay to be installed to work.
  • Added a conversion from Arnold standard surface to CoronaPhysicalMtl.
  • Adds decals to Lister with the main properties accessible.
Bugfixes
  • Fixed issue where decal with refraction intersecting solid objects could turn the object into medium container and thus influence the rendering of other objects in its vicinity.
  • Fixed issue where production denoising was applied after interactive rendering has finished.
  • Fixed issue where shadows from clouds were taken from a wrong environment map when using SelectMap.
  • Fixed changing of cursor to type after tone mapping reset in VFB.
  • Fixed Corona Camera’s parsing of animated clipping checkbox value.
  • Fixed BloomAndGlare alpha to update the VFB content.
  • Fixed wrong TileMap’s gapBlur parameter name.
  • Fixed issue where Ambient Occlusion with Outlines enabled in the scene would cause the rendering to get stuck.
  • Due to its inconsistent behavior, we have disabled drag&drop of multiple assets from Cosmos.
chaos-corona-13-3dsmax-daily-2025-05-30.exe
  • Added support for exporting animations to Vantage.
  • Added support for AI Enhancer in Chaos Cloud Collaboration (new CMasking_AiEnhancer element should be added).
  • Minor fixes of VrScene import dialog.
  • Moved firefly filter to the Scene Rolout and reduced the strength by a factor of 5.
  • Added basic support for Cosmos variants.
Bugfixes
  • Fixed issue where Out of core textures sometimes stored files on disk even when disabled.
  • Fixed issue where IR was restarted when selecting CoronaCamera while on Max Modify tab.
  • Fixed issue where applying decal on top of particle system could make the particle to disappear.
  • Fixed issue where plugging ray-switch material into outline material would lead to crash.
  • Detection of camera being inside medium uses new robust algorithm that ignores volumes created by “planar” geometry. Scenes before this fix are not affected.
  • Fixed issue where Corona Sky was not working in Corona Standalone.
  • Fixed issue where plugging Corona Sky into Corona SelectMap may lead to evaluating Volume effect from de-selected Corona Sky.
  • Fixed crash that could occur when drag&dropping older assets from Cosmos.
  • Fixed newly created CoronaLights missing viewport gizmo rays.
First Release Candidate for Corona 13 is here!
Please check this article covering the risks of using daily/non-final builds: Daily Builds FAQ
Drive link: chaos-corona-13-RC1.exe
Also: Link in My Chaos.
  • Scatter: Added option to generate clusters. Clusters can be generated, mapped using instance color map or painted via layers.
  • Improved controls of Thin Film in Corona Physical Material.
  • Added option to disable ACES OT operators in the warning message.
  • Set IR pass limit to 200 by default.
Bugfixes
  • CoronaBitmap selection dialog would default to ACEScg on load. Now it remembers last selected bitmap info.
  • Fixed issue where some fireflies were not removed.
  • Fixed issues with scene/material conversion of the imported vr scene.
  • Fixed issue where node visibility was not updated in IR.
  • Fixed issue where convex objects could create outlines where they should not have been.
  • Fixed issue where at very rare occasion scene would be empty when starting IR.
  • Scatter: - Fixed crash that may rarely happen on scene reset.
    • Fixed issue when the edge trimming was not fully respecting final transformations.
    • Fixed behavior of the edge trimming for grouped/hiearchical models and their children.
