Chaos Corona 16 for Cinema 4D Previews (daily builds) - Changelog
Please check this article covering the risks of using preview builds: Daily Builds FAQ
Use preview builds at your own risk and always make backups of important projects before opening them with a preview build installed.
You can download this build from Chaos account’s downloads page or Google Drive.
Changes in Corona 16 for Cinema 4D (Preview):
Fixed:
  • Fixed ports in Corona node material editor generated for glints in Physical materials
  • Fixed VrScene export (and upload to cloud) not working on macOS
  • Fixed not working denoising in CLI version of Corona Image Editor
  • Fixed issue with UVW tile/offset not properly affecting viewport preview when using experimental enhanced material preview in viewport
  • Fixed issue with many Cosmos materials using UVW being incorrectly exported into Vantage
  • Fixed issue with Corona Bitmap UVW channel overrides being incorrectly exported into Vantage
  • Fixed issue with camera resolution override not correctly updating aspect ratio for renders in viewport
  • Fixed issue where shadows of objects where translucent when exported to Vantage
  • Fixed saving of images generated in Veras in integrated browser on macOS
  • Fix of flipped Normal map imported from Cosmos
  • Fixed occasional crash when AutoAdjustment is enabled (mainly reproducible in IR)
  • Fixed incorrectly resized Veras window after first initialization on macOS
  • Updated Chaos Unified Login, Chaos Licensing server, Chaos Cosmos and Chaos Cloud client contained in the installer
Note: Changes in this build will be released in a future hotfix for version 15
Added:
  • Added AI assistant (beta)
    • supports help with product usage, suggestions on improving the rendering, mood-match based on an image and scatter tool
  • Added Chaos notification system
    • see documentation on how to manage settings in Notifications Management
    • notification system is installed as a separate component and can be enabled/disabled in the initial installation and later managed using Installed Apps (Windows) or from /Applications/Chaos (macOS)
    • notifications are currently not supported on Intel-based macs
  • Improvements in Vantage live link
    • Added Vantage support for more MultiShader randomization modes
    • Added basic support for Vignette in Vantage live link
  • Improvements for enhanced material previews in viewport
    • Normal map support
    • Basic metalness and refraction support
    • Triplanar shader support
    • Support for Legacy material
    • Note that enhanced previews are still disabled by default in Corona preferences, but might be enabled in future preview builds
  • Added support for saving CXR with 16bit layers, reducing file size
  • Added Collaboration, AI Enhancer and Veras into CIE
  • Improved conversion of Cinema material using non-physical properties of Corona Physical material
  • Scale and density in Chaos Scatter Area include/exclude can now be adjusted using curve
  • Improved loading of bitmap with incorrect file extensions in Corona Bitmap
  • Significantly improved atmospheric shader
Fixed:
  • Fixed some DPI scaling issues on multiple monitors with different DPI settings in Corona Image Editor and Standalone
  • Fixed splotches on thin translucent objects (like curtains) when seen in reflections
  • Fixed cluster offset transform incorrectly scaling with cluster size
  • Stops saving all render elements in Corona Image Editor after encountering the first error (to avoid flooding user with errors)
  • Fixed random crash occurring when opening the Veras/Collaboration dialog, now the Veras/Collaboration dialog’s content does not have to be reloaded when closing and opening the dialog again
  • Fixed Vantage export for scenes containing object with very large geometry
  • VFB size is now correctly adjusted when opening from Picture Viewer
  • Fixed broken CXR file association when installing Corona Image Editor
  • Fixed blurred textures in viewport preview when using layered shader
  • Fixed command line CIE occasionally mixing different images together when processing multiple images
  • Fixed refractive roughness mismatch between Corona and Vantage
  • Fixed issue with roughness set to zero causing issues with Light Override material
  • Fixed reduced performance when using physical camera size and clipping
  • Default texture size is now taken from C4D preferences when using enhanced viewport previews
  • Fixed issue where NANs in roughness/anisotropy textures would crash physical material
  • Fixed issue with macOS installer unnecessarily executing under Rosetta
  • New Corona Camera now uses the same default focal distance as C4D
  • Fixed crash when opening some scenes with Chaos Scatter
  • Fixed UNDO in Chaos Scatter Area include/exclude reverting multiple actions
  • Render is now saved only when render finishes (i.e. is not canceled)
  • Clamp half-open slicer intervals to bbox to fix environment fireflies
  • Fixed issue where OIDN would denoise other passes less than beauty
  • Camera resolution override now works also with render queue
  • Fixed crash when using enhanced viewport previews with shadows enabled
  • Fixed NaN in some scenes with bump
  • Fixed possible freeze when showing progress dialog for some operations in C4D S22+
  • Fixed issue with some Corona preferences (auto save, VFB title) being ignored for Team Render
  • Sped up material preview rendering/updates by changing the license type. User with only one interface license will be able to render material previews with already obtained interface license
  • Custom level is no longer reset in materials when texture is linked
Changed
  • Corona now requires at least Windows 10
  • Updated Unified Login to 2026.7.8
  • Removed legacy VFB 1
Added:
  • Added option to set background image that is not affected by post processing
  • Added option to relight Gaussian splats (they will receive illumination from the scene)
  • SPZ format support for 3d Gaussian splats
  • Improvements in Vantage export / live link:
    • Corona Ambient Occlusion shader support
    • Corona Slicer material support
    • Improvements in Corona Mapping Randomizer shader
    • Improvements in Corona Volume Grid
  • Vantage live link should now work even accross machines, including live link from macOS to Windows running Vantage (we now use live link v2)
  • Chaos AI assistant can now read information about camera and environment
  • Added new mapping options for Glints
  • Added new Light analysis pass to multi-pass
  • Added parallax mapping for Corona physical material - can be enabled instead of displacement
    • Note that there is currently a known issue when the parallax is combined with decals - we plan to fix this in the next preview build
  • Added tint and other improvements to volume effect in Corona sky
    • New volume effect model was already active in previous preview build, but without proper handling for legacy scenes, this version fixes this by loading old scenes with volume effect switched to legacy mode (used in Corona 15)
Fixed:
  • Fixed opacity rendering in Vantage when bitmap uses Image Alpha as Mono channel output
  • Fixed region tool discarding regions smaller than 20x20 pixels
  • Fixes in handling of Corona Bitmap enhanced preview in Cinema 4D 2023 and older
  • Fixed subshaders occasionally not working in enhanced viewport (Front back shader, normal shader, triplanar shader)
  • Fixed issues in Corona UI on hi-DPI monitors when some newer versions of Redshift are installed
  • Fixed freeze in VFB pick tool in scenes with standalone Sun placed in a hierarchy
  • Fixed crash when VFB pick tool is used on object with normal map after render finishes
  • Fixed enhanced viewport material previews in Cinema 4D 2025.3.3
  • Fixed crash when loading scenes with Scatter that linked unexpected objects/tags
  • Fixed back thumbnails of objets with Corona materials in asset browser
  • Greatly improved performance of both initial export and later updates in Vantage live link
  • Fixed issues with Chaos Cosmos on hi-DPI monitors on macOS
  • ACES OT tonemapping operator in now disabled by default in scenes that are already set to use view transformation
  • Fixed intensity not applying in Vantage to light using IES
  • Fixed sphere light with IES pointing in the wrong direction in Vantage
  • Fixed rare random crashes when initializing new render
  • Fixed possible freeze when initializing view transform in Corona VFB
  • Tweaks in how AI assistant uses scatter tool (it does not use concept of layers anymore)
  • Render stats should now be saved also in 16-bit CXR (fixes resume render with 16-bit CXR)
  • Fixed possible long freeze when starting IR after previous license acquisition failed due to networking error
  • Improved error handling when some parts of sky model data is missing (i.e. corrupted or incomplete installation)
Added:
  • Added support for Cinema 4D 2027
  • Added exposure and clipping mask support in gaussian splats
  • Added support for importing parallax interiors from Chaos Cosmos
    • This uses new parallax shader also added in this version, but this version does not show proper UI for editing it - this will be fixed in next preview build
  • Assets imported from Chaos Cosmos are now automatically re-linked when opening on machine with different location of Cosmos download directory (when the assets already exist)
  • Added tool to automatically download missing Cosmos assets in the scene
  • Added support for rendering reflections/refractions of objects rendered via Render selected
  • Added support for simple linear motion blur for particles rendered via Render Particles tag
  • Added support for enhanced preview of Mapping Randomizer shader in viewport
  • Added support for parallax mapping when using triplanar mapping
  • Show warning when rendering with both ACES OT and OCIO view transform
  • Multiple cameras are now also exported in Vantage live link
  • We now detect errors and closing of Vantage when running live link
  • Improved progress reporting when exporting scene to Vatage via live link
Fixed:
  • Fixed crash in Corona color picker
  • Fixed bright scrollbar background in VFB sidebar (regression)
  • Fixed crash when closing CIE before denoising finishes (or possibly other action like opening another CXR, pressing erase, etc.)
  • Fixed possible crash in Corona node material editor
  • We automatically switch off parallax displacement (and use regular one) when using layered materials or decals, since for these parallax displacement behaves unpredictably - this also fixes issue from previous build where the parallax would simply not work when used with decals
  • Fixed crash when scattering objects on another scatter (regression)
  • Fixed issue with alpha source in Corona bitmap being ignored
  • Fixed “Export and open in Vantage” not correctly opening exported scene unless Vantage is already running (regression)
  • Fixed occasional “PREREQUISITIES_NOT_MET” error when importing Cosmos assets via Chaos assistant
This is our first release candidate, we will now focus on stability and fixes until final release of v16.
Changes in Corona 16 for Cinema 4D (Release Candidate 1):
Added:
  • Corona Image Editor on macOS now registers CXR files for opening from Finder
  • Improved speed of loading scenes with a lot of textures with enhanced viewport enabled
Changed
  • Updated Chaos Comos to version 2026.10.7
  • Updated Chaos License Server to 6.3.2
Fixed
  • Fixed some cases where notification center on macOS would randomly request access permissions for reading folders
  • Fixed possible crash when switching scene shortly after image with OCIO view transform is shown in Corona VFB for the first time
  • Fixed some edge cases causing freeze in scenes with OCIO enabled
