Chaos Corona 9 for 3ds Max - Daily Builds Discussion
Hi
Unfortunately can’t use two latest DBs (2022-09-13 and 2022-09-20) because of error I’m getting using IR.
I get a message that some bitmap was changed during the rendering and render had to be aborted (example attached). After that render stops. The thing is that I didn’t change any bitmaps during the rendering.
This error repeats quite frequently with different “maps that were changed” and makes work with IR not efficient because IR has to be restarted again and again. So I reverted to the DB 2022-09-06 - it works without this error.
Max 2022.3. Win 10
I’m getting this error also with DB 09.06 Max 2021 WIN 10
Yep, I’m also getting this error since updating to latest daily. Max 2023.1
Hi all!
I’ve installed the latest build “chaos-corona-9-3dsmax-daily-2022-09-20” and last night I crashes/malfunction with the CIE app.
I had 8 CXR files to elaborate, once calculated I’ve opened the first one, I did my editing, saved it in TIFF 16bit and each time I was choosing another CXR to open the app was crashing/closing without giving any error. I’ve tried more times and I was having the same behavior. The only solution was to close manually the CIE and open it again for each image.
This happened to my home’s workstation which has Win11.
Here in the office where we still use Win10 everything is fine and it works normally…
What could it be???
Thanks,
Dionysios -
Hey guys,
I have a couple of questions, are your textures stored locally or on some network drive/gdrive or something similar?
Are you able to send any of these scenes over to us? If so I can PM you a link to upload it to me.
Thanks,
Rowan
Textures are stored on Dropbox (I know, I know, this isn’t really recommended).
Btw; this is happening during IR.
Can you see if this happens when the textures are stored loacally too?
Please also make sure that the dropbox folder in question is set to be “available offline” or however it is called.
Cheers,
Rowan
The files are definitely located on the SSD (ie; available offline and not accessed via cloud), but it is possible that they were syncing at the time of error (but unlikely). Not sure if the error happens when Dropbox is paused.
Could you send me over a couple of the CXR files for evaluation? I couldn’t reproduce this issue here. I will drop you a link to upload files to me via PM
Cheers,
Rowan
Hi Rowan - That crash is gone but has been replaced by another one that occurs when I’m moving geometry with IR running. It blinks and hides all geometry for an instant and I only see my Corona sky for a second, and then crash to desktop. Minidump uploaded to the same ticket #56513.
Thanks!
Daniel
EDIT: Actually it seems to happen when I scale an object.
Well that’s some kind of progress :frowning:
I will try to reproduce it here and let you know if I need more info.
Thanks,
Rowan
Thanks, I’ve sent you the files!
In my case all bitmaps are stored on local drives. After this post of yours I installed DB 2022-09-20 and working with it for some hours, but didn’t get this error yet :smiley: If I’ll get it again I’ll send you some example scene
In my case the files are stored on the same machine but on network mapped drives.
Have you found any solution to this? I’ve noticed that I miss it too.
Uninstall and install didn’t helped!
Thanks -
This thread helped: https://forum.corona-renderer.com/ Corona 8 don't install scatter #msg203605
The instructions were a tiny bit unclear (the link to the file is at the bottom of the post). But I got it working without too much hassle.
Good luck
I have question about “Textures connected to CoronaPhysicalMtl, CoronaLegacyMtl, CoronaSkinMtl and CoronaHairMtl are now visualized in 3ds Max viewport (High quality viewport needs to be enabled).”
Are materials with triplanar also visible?
Thanks! I’ll try it too.
Take care!
yes!
Great news! Good job.
