Chaos Corona 14 for 3ds Max - Previews (Daily Builds) Discussion
Chaos Corona 14 for 3ds Max Previews Discussion
You can grab the latest Preview from: [Previews Changelog](https://forum.corona-renderer.com/ Chaos Corona 14 for 3ds Max - Previews (Daily Builds) Changelog )
Will be any support to CoronaSlicer in Vantage? We are very proud of the CoronaSlicer because it resolves so much problems,
But the problem now is that it not supported at Vantage…
Nothing planned at this time, but you can add your vote to the Ideas Portal at corona slicer mtl and Vantage | Corona Ideas Portal
Thanks - I’ve posted it and I post it here as well just for people to see as well:
As corona slicer getting more and more popular among the corona users community,
The need for the coronaslicer support in Vantage is getting bigger.
The corona slicer is a fast and wonderful solution and many times replacing the old Boolean prompts.
And now, as the Vantage is getting supported by corona - which is a game changer -
Those two features need to be integrated together. It’s like “half work” is done if the corona slicer is not supported.
Yes , I know that you have a slicer in Vantage - but the functionality is not the same while applying it in 3dsmax and it doubles the work if I need to start make it again in Vantage…
Please Please consider it !!!
Thanks,
Shaked.
i just saw the list of all the new things coming up on to 14 and god you guys are amazing.
i just had to reset my default settings to get it to work tho
Crash at max startup or opening a scene? Minidump and scene are always good to attach.
May be related to Corona system settings parsing, there are a lot of changes which relate to them.
I can’t find new Fabric material…
Yes I would assume that, as I ended up resetting and things seem to be working fine, i would note that i use VFB2 and the fact that it autoresizes the render when changing the window size goes a long way.
Known and will be fixed.
Update is live. Please simply redownload either from MyChaos or through GDrive link.
turns out i still keep getting a crash, every couple of times i would get an insta crash right after the splash screen. is there a way to report it or help in fixing it?
Minidump will be the first step to go with.
I too have a lot of crashes without reason, using max 2024.2.3
Same thing CharlyRT, a minidump is necessary for us to start digging in to what is happening for you. Thanks!
Yeah, I know the process just wanted to let it clear that hes not the only one, sometimes I have read for that confirmation too
so far so good great job.
A couple of small things.
The new fabric material doesnt display in my viewport.
The spinners - they act a little weird and sometimes dont work.
also the uvw real world and tripplanar options come and go - in this case, they are not here.
I tested it a bit, so far it seems like all the new features work fine, the spinners in CoronaPhysicalMtl are a bit twitchy, but when I turn on interactive rendering everything becomes fine.
I’m very glad that you took up my old request with a separate shader for fabric.
A couple of comments/suggestions:
  • Add a separate bump slot that would be superimposed on top of the parallax, with support for normal maps of course, after all, working with fabrics is unthinkable without additional maps for folds & wrinkles.
  • And most importantly, the shader does not completely cover our need to create velour and velvet with a small pile, sheen performs a similar function, but in a very distant approximation. It would be great to create an additional section in the same material that would imitate small hairs and their brdf using the same parallax, for example.
    And give us 4 parameters - Length
    • Width. Together with the general tiling this would allow for the overall regulation of the pile density
    • Angle relative to the surface (mappable using a black and white map). 0.0 would correspond to the pile direction coinciding with the surface normal, 1.0 - crushed pile, 90 degrees to the surface normal. With this parameter we could regulate how much the surface will shine.
    • Pile rotation along its own Z-axis (mappable parameter by analogy with Anisotropy rotation in a regular CoronaPhysicalMtl). The original rotation value can be set using a object’s UVs as in the case of anisotropy.
If you will add this, it would turn the game with fabrics in Archvis upside down.
Following up to my crash report, ive updated to max 2025, and reset all of my scripts and started adding them one by one. and it turns out its te Corona Render element Script which i have used for god knows how long yet when i added it into max with Corona 14 installed = Instant crash
on max 2024 and 2025. idk which exact line of code is casuing the crash but here’s the link to the script used in case it would interact in the future with any future scripts “https://www.scriptspot.com/3ds-max/scripts/corona-render-elements-manager
Could we have a dedicated button for Flip image in VFB? theres a loooot of wasted space, whats the reason to use the small arrow to activate it? even the shortcut its not practical.
This is why people say that VFB 2 has a poorly design.
Could we have a way to edit shortcuts?
