I just install newest max 2025.1 and newest VRay 6. Everything seems ok, but on chaos scatter panel, there is three buttons but without any graphics.
Hi, thanks for posting. Do you have anything in the create panel?
Standard icons are ok, but when I chane max to small icons it is gone. Chaos Scatter is installed and working ok.
Thanks for this clarification, I can reproduce the bug now.
There is an existing report about the same bug created by another support agent a few months ago (VMAX-14129). I will add you thread to it and raise the priority.
Great, thanks.
Hello Guys,
Any updates on this icon disappearance issue. Any help would be appreciated.
Thank you.
Hi, the fix will be added in a feature release. We will notify you when a fixed build is available.
Hope to get a fix soon. Will this fix work for corona as well, I mean when we install corona scatter also gets installed so will there be another fix for corona or will the Vray fix work fine .
Thank you.
Hi, the issue is fixed. The fix will be available with the next V-Ray and Corona releases which if all goes as planned shouldn’t be too far away.
Thank you Vladimir for conformation. Would love to see that update roll out soon.
Great, thanks.
Hi Guys, just a quick update. The issue with Corona scatter small icons missing got fixed with Corona 12 HF1 Update. Thank you for the update and the fix.
Big icons are still there in VRay for Vantage toolbar even I have small icons set in max.
They remain “large” on my end (but still visible). Can you confirm? The ChaosScatter icons should be fixed though.
sorry, wrong thread. Yes, scatter is ok. Vantage is visible but remain large.
Minor issue, but I logged it (internal bug-tracker id: LAV-2103).
yes, it is minor. But I cant dock it which is annoying ![]()
