Hi all,
I don’t think I’ve seen any post related to this issue.
We recently produce more animations, so previewing cameras movement in the viewport became very important element of production.
Our scene is split into many Xrefs, that made us realize that whenever Landscape Xref is loaded, problems arise.
We managed to narrow down the issue to Chaos Scatters. When scatters are enabled, (doesn’t matter in what display mode) viewport playback performance drops significantly. From 50-60fps to around 5fps.
(please note viewport navigation is fine, it’s about timeline scrubbing and playing viewport animation with “/” button)
When scatters are removed from the scene, all is back to normal.
Now here are some additional findings:
-annoyingly hiding scatters layer doesn’t help, changing visibility to dot, point cloud or even “none” doesn’t help.
-in order to bring back high fps, scatters need to be either removed from the scene completely, or disabled in the scatter lister.
-we are certain this is not just one of the scatters causing issues. Gradually deleting some of them helps (as per screenshot, we have more than 20 in file), so the more scatters we have the worse the issue is, 2 scatters will be ok, 10 will already affect fps heavily. etc
-fun fact, having Chaos Scatter Lister window open, again kills fps from 50fps to 5fps (even with scatters disabled).
-some screenshots for reference of fps values while scatters are disabled/enabled etc.
Can this be looked at?
We can send sample scene for tests if needed.
Just bumping this one up. Would be great if this could be improved in v10.
It’s really hard to work on animating cameras if viewport has 5FPS, and it bacame a real pain in our recent projects.
Disabling Chaos Scatters is not always an option, often we have them as a part of an xref, so in order to improve viewport performance in master file, an xref has to be opened and scatters disabled there…
Can we expect that team will have a chance to look at it in the new release?
Hi Romullus, yes just tried this, not a tiny difference in performace, just as bad as with autoupdate.
I did another test, added scatter with 50000 boxes scattered on the simple plane. This scene with highpoly models, 10mln Verts, is playing at 20FPS without scatter.
After adding the box scatter it drops down to 10FPS. Even if I hide scatter, it remains at 10FPS, only disabling or removing scatter brings back 20FPS performance.
Remember that I have flexibility to disable/enable scatters only if they are physically in the scene. If they are xrefed, there’s nothing that I can do to improve performance rather than disabling xref.
Scatters are rarely xrefed on their own, usually they are part of landscape/context file, with all the paving and other elemnts that are essential to be visible in the viewport while animating cameras.
Real pain to deal with.
Bumping topic up for v11 since I’ve seen there are some new features being added to scatter in daily builds.
Would be great to resolve the performance issues of the existing features if possible.
Hi Maru,
Hi, just bumping the thread up.
Was this fixed in latest Corona releases by any chance?
We’re still on Corona 9 but are hoping to upgrade to 11 soon if the issues with viewport performance have been fixed?
