Chaos Unified Login application is not running
I post this here because the main Chaos forum is truly terrible. I ask for your help.
I can’t make the Chaos Unified app run. I am trying to use Anima but it asks for the Unified Login to run in the background. The app is set to open by default at startup, but it doesn’t open. Even if I click on it nothing happens. I have uninstalled and installed back again the whole Chaos Licensing thing. I tried to disable my Avast antivirus-firewall but nothing again. Inside 3ds max, under the System>Chaos Corona/Licensing the “Chaos account” shows me that Unified Login is not running but the reload button do nothing.
Any help please?
Doing a deep uninstall seems that made everything work. For anyone who face the same issue, try to delete everything of Chaos Licensing. Go to AppData, Local and Roaming and delete everything that has to do with Chaos License server. Shut down your pc, open it again and try a clean install. That worked for me.
Hi, I understand the reason your posted, but neither of the forums is a good place to report licensing or payment issues. The best you can do is start a support ticket at https://support.chaos.com/hc/en-us/requests/new
This ensures that the right team will take your ticket and provide you with help.
Thank you for posting the solution here. I had the same issue and waited in vain for hours for Chaos support to respond. I tried a full uninstall as you suggest and it worked…
Thanks for your process. That seems to have corrected it for me as well, almost 10 months later.
