Color management in C4D 2026
Hi, I switch to C4d 2026. What is the best setting for the color management for the scene ?
Still in legacy sRGB or the default C4d ACESsg. Thanks
You can use the one you prefer. Generally, I would recommend using the ACES workflow if it is required by your pipeline (e.g. you are using multiple devices or apps that expect the input to be in ACES). Otherwise, you can use the sRGB workflow, it will not make your renders “worse” in any way.
When working in the sRGB mode, you can enable the ACES OT operator in the Corona VFB and this will give your images almost identical appearance to what you get with ACES workflow.
Thanks Maru for your answer
