I’d recommend updating to the latest version of ForestPack Pro (6.3.1). The issue should be fixed with this version.
Thanks,
Rowan
Thanks,
Rowan
Hi, hope it’s okay to mention a similar error in the same thread:
Corona 6 and Forestpack 6.3.1
RT crashes if you switch to “Edge” mode in Areas while the RT is running.
This seems to work okay for me. Can you provide your scene?
Instructions on how to do this are in my signature.
Rowan
Interesting. I’ve attached the scene using the uploader. The file is called “Test_AfterOptimize.max”
I’ve also attached a minidump called “3dsmaxminidump_Test_AfterOptimize.7z”
Both files are linked to "https://forum.corona-renderer.com/ Corona 6 + Forest Pack error "
Max version: 2020.3 Update. (22.0 - 22.3.0.3165)
Corona version: 6
Forestpack version: 6.3.1
Here’s how to reproduce:
While writing this and trying to reproduce this, the program has frozen every time at point ![]()
As a test I tried to save the scene before using optimize function. and one after, and the scene with optimize freezes every time I move/pan camera in RT.
I think the “Optimize” function in forestpack might be the culprit. But I have not tested adding the edge map manually yet.
Please let me know if the upload didn’t work or if some more information is missing.
I don’t see the files in our uploader.. It could be that there was some issue with the upload.
You you try to use our dropbox uploader, instructions on how to do this can be found in my signiture.
Cheers,
Rowan
Ah, I had a feeling something was wrong.
I’ve uploaded it again but through the Dropbox option. It’s linked to my email
I’ve also attached the scene before I did Optimize, this one does not freeze
Thanks for reporting this, I can now reproduce it in your scene. Which is strange as I had exactly the same setup.
I will forward this on to our dev team.
Cheers,
Rowan
(Internal ID=435709873)
Did you try with the latest version of Forest Pack?
Rowan
Tested with FP 8 and Corona v10 DB 2022-11-25 and this no longer crashes.
