Corona bitmap cant load Exr Sequence
Hi, i was testing an Hdri animated footage that you can find here Free HDRi Sky timelapse • Freebie And i find that Corona Bitmap cant load it and this error shows "Could not load texture file: Reason: Unrecognized image file format for filename " If i use 3dsmax regular bitmap it loads fine.
Using max 2021.3 Corona 6.1
Not exactly a bug, just not supported. Requested multiple times though. Also see
https://forum.corona-renderer.com/ .ifl file support #msg179752
Good Luck
This is a duplicate of the above report mentioned by Frood.
(Report ID=CRMAX-282)
