Hi guys, I have a strange final result with a new CoronaPhysicalMaterial. What can be the reason? It gives different results & more noise with the same settings. Thanks
New PhysicalMaterial implies a relationship between the glossiness of reflection and glossiness of refraction, in this case both are equal to 0.8, in the first case with CoronaLegacymat the glossiness of refraction is equal to 1.0
You can’t achieve exactly the same effect using the new CoronaPhysicalMaterial, meaning that in real life if you roughen the surface of a refractive object to get blurry reflections, the refraction itself will also be blurry.
You can set the glossiness value to 1.0 and add a clearcoat layer on top with a glossiness value of 0.8, but keep in mind that the 2 reflections will overlap each other and the result will not be identical to the first, so just use the old CoronaLegacy Material
