corona materials library , how to dial with them ?
hey
im new to 3ds max and corona, i just purchased a license for corona
i like the materials in corona library but when i try to drag and drop them on object ,
and hit render, the result is a plain color !
how i can make materials appears exactly like that ones in corona materials library ?
do i need to make some configurations after applying the material to object :confused:
thank you in advance
I assume the reason would be because the materials are set to use real world map size in most situations. You need to set this in your uvw mapping to see correct results.
Hope this helps
