Corona Plastic Material (Grant Warwicks Method)
Hi.
I tried to apply Grants approach on creating realistic plastic materials in Corona. I used standard blend for mixing materials and a falloff mask for blending the two. Sadly only two materials can be blended and there isnt any extra slots for the 3rd or 4th materials. Im not getting a good result out of this. Is there something wrong with my material setting? Has anyone done this in corona with decent results and how?
P.S: I read the ggx thread but couldnt find any pipelines or solutions to do this in corona.
Firstly you need to change the IOR to 999 to deactivate it and allow the falloff curve to control IOR.
Secondly, in the GGX thread there are diagrams showing the nesting concept with multiple blend maps, however I will repost.
Although for Gold the concept is the same, you can also download the material off CML:
http://coronamaterials.com/
Thanks dude ive been looking for this like forever! one question tho, the IOR value in all the base,coat and gloss materials must be set to 999, right?
Yep, if the material IOR is driven by a Falloff Map then the standard IOR needs to be off.
I tried to recreate the plastic using multiple blended materials with different ref glossiness and falloff map used for reflections. What do you think of it? Any suggestions to make this better?
Someone correct me if I’m wrong, but we don’t need multiblended IOR materials anymore now that we have CGX built into Corona 1.0?
Are you saying that by only entering the fresnel value we get realistic shaders? Cause I for one havent been getting anything decent.
Thanks man. Very informative.
