Hi. I have problem with scatter. If I use scatter with rotating object, for example cylinder, scatter objects has little moving and disappearing when rotation.
Please examine this video and help me. Thank you
How cylinder is rotating? If that’s just simple transformation, that shouldn’t happen. Also can you show your scatter settings?
This is a another problem example. If I bend edge of the cylinder with taper, scatters start rotating. This is worst than other.
The strange thing is that if I animate the base object, the scattered objects do not animate at all in viewport unless it’s refreshed. They just stand still until I move something. I am using the 11.04 build. Could it be because of the nitrous improvements?
Are those scattered proxies animated by any chance? But even so, it shouldn’t behave like in your vid. Can you share a simple scene where that happening?
@maru: i’m on the same build and i have no problems with updating. Maybe it’s down to the max version? Mine is 2014 sp5.
No, any object has no animation. This is a basic scene. Only cylinder and scatter objects. I tried two version of max. 2014 and 2016. Both of them has same problem. I send you this basic scene.
scatter+problem.max (304 KB)
Ok, that’s really looks like a bug. Moving topic to apropriate board.
Thank you for your interest. If you correct this error so I’d appreciate it. Thank you again ![]()
we have a prototype where this is fixed, but there are still some issues to figure out
Fixed
Wow, Thank you for interest ![]()
Hi Ondra.
Can I download this fix it somewere? I have a very short deadline and It will save my life. ![]()
Thank you
it is in daily builds, see the section here on forum - but beware of the recent shading changes - backup everything first
