Corona to Vray Converter ?
Is there any corona to vray converter ?
We are getting max files from architects using corona and need to convert the scenes.
hm, I know it onlay the other way round… Corona Material/Lights Converter (legacy) - User Contributions - Chaos Forum
sorry
themaxxer
Yes, there is. Check this link:
Thanks. İt worked. Gave an error on lights but materials are ok.
Silly question, do I need to have corona installed for the script to work?
Yeah.
Already an old topic.
Seems the converter doesn’t work on lights and proxies..
Is there any way there will be a good script in the near future?
The other way around is so damn easy.
I do some projects in Corona if i work with someone else, but myself prefer Vray. But the hassle it takes to get all the lights and proxies back to Vray makes me think i continue in Corona.
Will we ever see a converter that works? I am seeing more and more models that I want to buy, but they have Corona materials, but I can’t because I can’t convert the materials.
Well that should tell you something. Either jump ship and switch to Corona, or just get yourself UMC (Universal Material Converter) by Stefan Twigt
I’d go for the 2nd option.
See a working example:
And grab it from here:
http://www.3dstudio.nl/webshop/product/1-universal-material-converter
One suggestion though, I don’t know if Stefan implemented it yet, but his script works almost too good. I suggested he gives an option to ignore Dispersion or switch it off. If he didn’t get that far yet, then use Olly’s VMC script to switch off Dispersion on the VRayMtls after you used UMC to convert (It’s basically the Abbe number for Refraction)
The regular V-Ray scene converter will convert Corona materials in some basic form, so it could be a starting point.
I ended up installing Corona and using a script I found on-line. It did the job, sort of; reflection and refraction was set to pure white.
I went to convert a model in my scene, but I converted the whole scene. I purchased the UMC script, but I have to wait for a license, I guess. I read their forum, what I could because it isn’t English, and people are not getting their code. Is this a dead script or is it still being developed? How long to get your code?
I have the UMC script as well, and I do get upgrades from time to time so not dead. However, I’ve really never gotten it to work. I import Revit files with Autodesk materials and after conversion to Vray they are still there, as far as I can tell nothing happens.
I got my license and it seems to work, somewhat, but not enough to save me. It doesn’t seem to work on sub-object materials, which is 1/2 my scene and all my Forest Pro stuff.
Ah, maybe that is the same thing I’ve experienced. I just noticed there were still Autodesk materials but never investigated further.
Multi/sub materials should be easy to fix, maybe the author can do it relatively quickly.
I have the same problem. nothing happens. the older script of them has worked better. I use it if nothing happens with the new one. :slight_smile:
years later… I received Corona files from another firm. A landscape loaded with Corona proxies. I have looked around for scripts but have not had not luck with anyone that works. Any suggestions?
If not, What is the general labor intensive process?..1. select corona proxy, convert to mesh, convert to V-ray material, then make it a V-ray proxy? Thanks in advance
