Hi!
Do you have someone ready or is it possible to create a converter CoronaProxy from VrayProxy ( VrayProxy->> geometry->>CoronaProxy) ?
Yes. Very good. See my answer in theme about animation.
VrayProxy 2 CoronaProxy v0.2
Written on my knee.
Until a obj file.
Use at your own risk.
- Select VRayProxy object(s)
- Press “Do it”
Defaul to save the obj-file path is used max-file, but you can specify your path, but not necessarily.
VrayProxy_2_CoronaProxy_v02.mse (2.31 KB)
Ecximer. Thank you very much, Man !
Thanx a lot friend!
Hi, have you thought of updating your VrayProxy 2 CoronaProxy script to support new corona’s proxy meshes ? It could be even better if you could teach this new updated script to somehow replace links to original vrayProxies in multiscatter with new converted corona’s ones if it is possible to do by script of course. It would be quite useful to have such one I think, it + Martin’s material converter + GroveR_GoL’s scatter converter (if needed) could make converting some old exterior scenes a breeze instead of a shitstorm ![]()
