Vray proxy to Corona proxy converter - update 05/03/2014
Vray proxies to corona proxies converter
There is a repository on github, download from there:
https://github.com/pavel-mxsf/coronaConvertProxies
DIRECT LINK: (rightclick and save file as…)
coronaConvertProxies.ms
  • currently .ms only - run by dragging coronaConvertProxies.ms to viewport or maxscript - Run Script
  • for material conversion run and close material converter first.
Any forks are welcome
UPDATE:
  • corona final fix
perfect. thanks a lot
Thanks, it works and it works good ! Tried it on quite a heavy scene and it worked pretty well.
Now it would be even better if anyone could do some kind of script which not only converts vray proxies but also can kind of relink those which are already used in multiscatter/multipainter (for example) thus keeping their position, scale, variation etc. of course, common sense is telling me that should be possible to do only on multiscatter developers side - inside the plugin itself or maybe it already got such function but I just simply overlooked it (it does happen sometimes :smiley: ) and if there is such a thing someone please elaborate me.
For now I found comparably easy method by using Generate Objects in the MultiScatterTools , deleting original Ms helper/gizmo after that and then running your script - thus, even if loosing Ms objects themselves :frowning: one can quite easily convert some vegetation heavy vray done exterior scene in no time, if not for material tweaking afterwards of course.
Thanks again !
and it is not working, antanas? you need one proxy piece picked from multiscatter, right? and when you convert this proxy multiscatter distributes converted version. this should work.
Thanks, it works fantastic!!!
Holly Cow this works great!!
Thank you very much.
Oh sorry, it really does work - something went awry the first time I tried (that was some quite big 2year old cityscape scene I’ve tried that on, so it’s kinda hard to keep track on everything) and thus I assumed it does not relink or maintain that link to Ms and thought of that now stupid sounding method which I described :smiley: but it does maintain those links !!!
Thanks again for your script - vray to corona scene conversion was never so easy.
Maybe if I’ll get some free time I will rework/update that scene and see how it fares in corona, which already looks promising at least in terms of render speed, even after just running your script and material converter, and with all that post conversion albedo/glossiness madness, 4k resolution renders something round 10-15 min compared to something more like 2h in v-ray on the same hardware, of course without vrayEnvironmentFog (which does slow down rendering quite considerably) and without working richdirt (which doesn’t slow down rendering too much) - but still, wow !!!
because this is not maxscript code but xml code. click RMB and Save link as in this section
"How to run
Download coronaConverterProxies.ms …"
Great tool! But now is not supported v7
it will probably work when .cbin/.cmesh is replaced with .cproxy in the script
updated on github, download new version
When i run the script i get this error, any help?
you saved a html page instead of the script
Great tool, thanks a lot :laughing:
i got Error on Corona 1.0 :frowning:
There is one bundled with Corona 1.0. Try that one :wink:
can´t find him…
It’s located it “3ds max 20xx\scripts\startup” and will install automatically as macroscript. You will also find it as a menu point in the right click menu
Yes, I found it. But´s the CoronaProxy exporter. I´am looking for the vrayproxy2coronaproxy converter…
