Could not Located Chaos Unified Login Service
Hi i am using Fixed License Yearly licence [ A-S01921815 ]
I just installed new enscape. I buy the license from other email (different with my sketchup, i don’t know if it cause issues)
but I have problem logging in - this error message popped up: Could not Located Chaos Unified Login Service. I opened the Chaos Documentation Website link as suggested and downloaded License Server hoping to install the License Server.
Right after i installed the License Server apps, i can open and use the enscape, but the status is still not login, I can’t use the AI feature because i’m still not sign in.
And when i open it another time, i got the License Notice again and have to install the license server all over again.. (should i do that every single time i need to use enscape? very inconvenience)
The “Sign In” button also not work, can’t be clicked.
I already read all the guide from chaos web and this forum but still got no answer that work for my problem.
Hi @shintiaprila and welcome to our Forum.
In this case especially when it comes to any ongoing licensing issues (or problems with your license/license server in general) please kindly reach out to our dedicated support team directly as detailed here and you’ll be assisted shortly thereafter. Thank you in advance for your cooperation as well.
hmm i already contacted the support team from the application before i make this thread. But i don’t see any response. Or, where they give response at?
In this case I reckon you’re using a different e-mail to log into this forum so I could not find any relevant requests of yours just yet.
You can feel free to share the e-mail used to contact us though (likely the one used to purchased Enscape) via a direct message in this forum (as detailed here) and I’ll check if we received your inquiry properly.
