could you Share one wonderful indoor vrscene.
At first,Thank you vrey much,vantage is wonderful app.
But to use it perfectly isn’t easy, interior objects have many details,the Lights(hdr,plane light, spot light,ies…) are to hard to render good.So could vantage share one indoor scene to show the skills how arrange Lights. we need a example to follow.
a scene can be render panorama image is better :slight_smile:
Hi max_romju,
Lights in Vantage should render the same as in V-Ray. Can you explain what do you mean or are there any differences (beside the shadow bias that is scene units dependant) that you found?
Alexander
thank your reply ,but I do’t have any appropriate examples now.I wil post here tommrow.
by the way ,the vraylighmtl be rendered same both in vray5 and vantage?
For VRayLight material Vantage supports:
  • Color
  • Color multiplier
  • Direct Illumination On
If the material doesn’t have Compensate camera exposure enabled it should render the same.
Alexander
max 2020 +vray5
And vray Light test in Vantage.The filesize is bigger than the limitation of upload,I have to delete many data,So the photo doesn’t match the scene.
Vantage does only 2 GI bounces by default, and in your scene the lighting setup is somewhat difficult - the light needs a lot of bounces to reach the walls.
You can increase the number of GI bounces to 4 in Vantage to have a better matching result.
Another solution is to change the lighting, so it needs a smaller number of bounces to reach the walls.
Your test images don’t match the results I get here - the V-Ray CPU result is much brighter compared to your image.
Greetings,
Vladimir Nedev
The option “Clamp secondary rays” may also reduce the amount GI.
Firstly, that file contains an ALC virus corruption.
Something is clearly wrong with the scene, as when I rebuild it, the result from Vray and the result from Vantage are identical.
Also, within your scene, when it is exported, there are two extra cameras that are created, whereas there is only one in the scene before exporting (virus related?)
Personally I would reinstall Max and leave out any dodgy plugins or scripts that you downloaded from places that cannot be verified as virus-free :slight_smile:
You will know it works if you make a scene and transfer it to Vantage without issue :slight_smile:
In any case here is the max file and its vrscene after export.
I’m sorry,the vantage config is my mistake,vantage is greatfull.
What was the mistake in the vantage config ?
Greetings,
Vladimir Nedev
in the wrong exposure cam viewport ,I havent noticed the shutterspeed has be changed ,:rage:
