Cubemap Stereo rendering wrong aspect ratio
If you render a 6 x 1 cubemap in stereo mode it only renders every cube as a half-width cube instead of a full width cube. Is that an option somewhere you can disable to do a 12x1 instead of a 12x1 anamorphic in a 6x1 aspect ratio?
There is an option Adjust resolution in the V-Ray stereoscopic settings. It will automatically adjust the render resolution from 6x1 to 12x1
Thanks, that somehow got disabled. I’m pretty sure it’s usually on by default.
it’s not, always needs changing with a new helper
