Darn RedDots - I curse them!
And here we are again:
I got the scene, modeled the objects, animated them etc. Rendered a test, what do I see? red dots. Went in, made sure I dont have any wierd 3rd party messing up the scene, applied cropping to all maps using that cropping script. Rendered and they are still there. Vray log doesnt say anything about overbrightened mat or anything…I must know how to solve it before we start rendering for production - or my head is off my shoulders.
Please help.
http://www3.telus.net/public/vinnik88/temp/cdrp.mov
any missing uvw’s?
otherwise we will miss you :stuck_out_tongue:
let me check…the thing is that red dots appear on the container itself so it seems to me that its texture/shader is causing it.
If you send me an email to vlado@chaosgroup.com, I can get you a patch that will most probably make them go away.
vlado just sent you email.
is this the ‘ward’ thing?
got it on a couple of mine too until i stopped using ward.
i guess there’ll be a .16 to sort this out soon?
I found strange red artifacts in some renders using 1.45
When I changed to 1.46.16 they disappeared but, rendering was longer.
where did you get 1.46.16 from?
I meant 1.46.15 - sorry mistake.
Vlado, the patch didnt work and i still get the redDots…:frowning:
Yellow Dots
I was getting yellow dots in a scene recently. I had to go in and remove them by hand from all of the cursed frames since I couldn’t find a way to make them stop.
I had really bad dots before I removed an architectural glass material from the scene. I suspect that my yellow dots were coming from some other bad material, but I couldn’t find it. Maybe it was an object without material… don’t know.
My dots were exactly the same as yours, though (well, other than the color). They randomly showed up throughout the animation.
I got them as well, even on surfaces with no glossy effects ie the wall behing the picture. the materials are set to blinn. using 1.46.15.
It usually shows up on glossy materials
Colin
ps excuse the render quality, still fiddling with this sucker :smile:
I’m starting to think that my spots were, in fact, red. I got some yellow blotches because of a bad material in the same scene, but I think the spots were red. Not that it matters - spots are spots.
whats funny is the red dots are green in VFB…
Do the spots go away if you use the material over-ride and give your entire scene a standard material? I think they are material related.
verywell can be
also do they go away if you turn off glossies in the global rollout? my bet its somewhere in there.
strange thing:
if i render a scene with quasi for both gi methods and get planty of red dots, but then i rendered same scene with irradience/lightcache and no red dots…
This is really strange. I NEVER had those red dots…
I almost always use VrayMats (rarely touching ward), avoid Standard Materials when i can and keep my fingers from all the other materials that come with max. Especially those that involve max default raytracing stuff. (Raytrace, Architecture) I do that not because i always avoid getting dots but because i simply can achieve most things directly with the VrayMat.
You guys must use something i just don’t.
It would be nice if Vlado could figure this out though. It seems many people have serious Problems with it.
Vlado’s patch did not work?
