denoiser doesn't update after a lightmix change
When making changes during rendering, all is fine, but as soon as you stop the rendering, the denoiser seems to calculate but if has no effect on the end result.
5.20.20
Does this happen with all projects or with a specific one?
If it happens with a specific one can you please share it so I can investigate it on my side?
If this is alright, please use the Pack Project tool (V-Ray > Pack Project) to make an archived copy of the project and send it via the link below or a file-sharing service of your choice.
https://support.chaos.com/hc/en-us/requests/new
Hi @Gijs ,
I am not able to reproduce the described issue.
Can you please share more details about it?
A list of the exact steps you take will help a lot.
Thank you in advance,
Konstantin
I have exactly the same issue as Gijs.
In my case, after I do any modification in the light mix I could see that everything gets updated, but the denoiser won’t work even though the denoiser icon is enabled.
I have to disable the icon and enable it again for the denoiser to work. So, I basically have to manually refresh the denoiser.
I have this issue all the time with every single project.
I observed thi issue too…
