Displacement bug with n-gones
hello,
When using displacement map material on n-gones, black lines appears at edges positions.
So how to make float coating with corona ?
The file has been removed? Can you share it again? Can you share an example of what you are trying to do or what is going wrong??
Try disabling the new 2.5D displacement in the render settings.
