So, I have a scene that renders fine using CPU on both my desktop and render node with Distributed Render enabled, and Output Size set to W-5000x H-3235. Problem is when I increase the Output Size upto W-6182 x H-4000, the log says there is no work for the render node to do and it’s not being used. If I set DR to only use the render node it renders only using the node.
Why would increasing the Output Size cause the render node to not be used?
