Since some time the distributed Rendering is not working for me..
I use 3ds max7 and the newest version of vray (1.47.03).
Everytime i want to render 3ds max ask for saving the scene..
and the only (for me) visible message in the log is : Render host *** failed
h.kroeber I am having the same problem but in Max 6. Everytime I try to start DR it asks to save the scene and then I get output from only my main workstation and not my server machine as it says it has failed; this is in the log like yours. Look at my post http://www.chaoticdimension.com/forums/phpBB2/viewtopic.php?t=11680
I have followed all the steps in the Help index and yet DR will not work even with a simple sphere and Vray plane with no maps.
Too bad as I am, as I assume you are, looking forward to using DR as it is certainly a powerful feature and I would say a critical one in a third party renderer. Anyway hopefully someone can help us. I have also sent a tech support request to Chaos with all my logs to get this figured out.
Good luck to you h.kroeber and I will post any solution I get so you can try them on your end too.
rpc212
