DomeLights not working with Maya RT ?
to recreate the problem:
-Create an sphere
-Add a domeLight
-Map a texture , we tried tiff and even exr
-Render with regular vray , result OK
-Render with RT , result all black, NO OK.
Is this a bug , am I doing something wrong ?
We are using latest production release 2.004
Thanks in advance.
Alex.
Worked fine for me when I tried it; are you using the official build from our site?
Sure all official , downloaded from your site. Will try again from scratch and let you know.
Thanks,
Alex
Hi Vlado,
found the solution, there was a Vray.exe Service running , I remove it and now it works great. Dont´know why this happened but I thought you should know.
Thanks for your help.
Best regards.
Alex.
Ok then, glad that it’s sorted out. As for the service, if you are storing the textures on the network, you need to set up the service to run with under a user account that has access to the network location.
