DR stopped wokring
Hello everyone,
I recently upgraded from vray 1.5 to vray 3.0 for 3ds 2011. I was so happy I decided to try it on 3ds 2014. As soon as I installed it DR stopped working. As if the render nodes cannot obtain license through the network. I tried to test it through the back burner technique but no luck.Any thoughts?
Thank you in advance
Im re posting here as it is more relevant - Chaos Forums
I see that you have a support ticket opened in our system, so my colleagues will help as soon as possible.
Hello Tashko,
yes thank you very much.
No luck, it seems that the nodes cannot retrieve the license from the main machine since if I type the getstatus on every node I don’t see the license page
Are you sure the license server is running then?
Hello Vlado,
Problem was just solved. I called my IT and said that the main machine was blocking the render nodes from retrieving the license.Problem was I couldn’t see the getstatus page from each of the nodes. I don’t know how this happened as they were no firewall changes applied. Something to add in you knowledge base. Thank you for your support
Antonis
Thank you very much for your update. Glad to hear that you have sorted it out.
