Vray 3.10.03 DR not working on farm nodes
We have updated the farm to 3.10.03 and the no DR issue persists. The V-Ray message window instantly give the “actively refused the connection” error.
This problem occurs from any host to any node using any file.
Windows firewall is off on all the render nodes
It does appear to work from workstation to workstation, tried on two different workstations.
Vray 2.5 under Max 2014 can still DR to the same nodes
For fun I checked out dongle, the vray 3 entry mentions nothing about DR licenses. The 1.5 entry does, phoenix does but the VRay 3.0 only mentions “render licenses”
is that for normal farm use and DR? Just want to make sure that is not the issue. No matter the case there are 49 “render licenses” free.
Update:
So they are referred to “universal” render nodes so I assume that means DR or otherwise.
Thanks,
-d
Anyone? This is crippling.
Some info clarification:
MAX 2015 SP3 Ext2
Vray 3.10.03
Happens via Deadline 7 or direct DR using only max/vray, local host or not
I may know what it is. We upgraded to 3.0 and injected the new licenses into the donlge but never updated the license server software. We are going to do that tomorrow.
Will post results then.
Update, the license server was updated so that is not it.
Ok so checked the license server directly.
It says 2 is 3.00.07
and 3.x is 3.00.08
Wibu key 6.20
Do we need to install the license server again using the 3.10.03 install package or will should it work anyway?
I see that you have created a ticket in our system about this issue.
We will reply to it right away.
yup thanks
Ugh this turned out to be the port. It needed to be switched from 20212 in Deadline to 20204
Thank you very much for this update.
same prome from yesterday when I’ve installed 3ds max 2015 with EXT2 and Vray 3.10.03 on windows 8.1… when launching Vray Spawner, Max opens with a generic untitled file, not the correct vray dummy…
tried on a pc with windows 7 and it works fine…
V-Ray spawner doesn’t switch to a dummy scene with the latest version 3.10.03 used on 3ds Max 2015 EXT2, but it should work fine. Please run a test render to confirm this.
Thx Tashko…
now it works… it seems the problem was that I have upgraded to Vray 3.10.03 on the host but left a previous version on the servers…
