I just installed both Max 2016 and the latest VRay build onto my other computer and I’m trying to get DR working again (I had it working fine some months ago with 2015). The log tells me everything is fine with the connection to the other computer, but buckets from it never show up.
That does not appear to be the problem, no. I’ve got Backburner working fine on both, so I’m rather clueless what it might be. And to clarify, the log tells me that the render has started on the other computer. I just never see any evidence for it.
Make sure you are using the version of the spawner that goes with the version of max you are using. I ran into something similar and turned out I had max 2014 spawners running on the farm and not the 2016 ones.
