I have kept Ultra HD rendering quality, and the rendered model looks high quality but when I export it to image it all looks blurry. All the settings seems to be correct. I have kept image quality to ultra HD, I have turned of lens blur etc etc.
My system details
Using Revit(2023)+Enscape(3.5)
12GB VRam
32GB RAM
Ryzen 7
Nvidia GeForce 3060
Render Quality in the Main tab is the render quality of the live view and doesn’t effect saved images.
To improve the quality of saved images, go to the Output tab and increase the Resolution.
https://blog.enscape3d.com/export-options-in-enscape
Thank you for the reply.
I have kept Ultra HD in output tab but still the quality is same(Blurry)
Could you perhaps share the original rendering in Ultra HD as well? The example you’ve attached is only 1280x948, so basically just HD, which would explain the blurriness.
Just in case Enscape seems to only produce renderings with a lower than Ultra HD resolution no matter the settings, could you please also send me a screenshot of your output tab just to make sure?
Thank you in advance!
set is to custom resolution and try 4000x3000 ( or whatever aspect you want) and see if the resultant jpg/png is still blurry
Please make sure Auto Focus is enabled, otherwise the image may appear out of focus.
