Enscape Material Editor Does not Exist
Hello!
I use rhino 6 latest version and Enscape 2.4.0385 but I cannot see Enscape material editor.
Do you have any ideas why that is happening?
Thanks in advance!
Please make sure you’re running our latest version of Enscape, the version 2.4 is already rather outdated and did not include the material editor yet. :slight_smile:
I’ve notice that if you right click on the Rhino toolbar to show or hide different toolbars Enscape has multiple options. If you play around with which option is shown then your material editor should show up again. (hope this helps) Seems like Enscape isn’t cleaning up the old junk when installing new versions which may be causing confusion in Rhino.
Good points! In this case it should be caused by the outdated version though - still, removing any older previous versions of Enscape before installing the latest release is indeed a good practice. :slight_smile:
