The Enscape material still assigned in the layer, and still shows up in the render screen, but does not show up in the editor window. (It used to)
I cannot edit the existing materials. Please help!
See screenshot attached.
@yushiro , welcome to our Forum,
I’m sorry to hear about that - can you make sure that you’re on our latest release, please? Which version of Rhino are you using and does it help if you first off re-install Enscape? Please give that a try as well.
Also, can you kind of pinpoint when this started to happen? Maybe after you’ve tried something specific? Can you perhaps also share a screenshot of me from one of the materials in Rhino itself so I can see the configuration is set to Enscape Materials? Thank you very much in advance.
Hi was a solution found to this problem?
Something similar happened to mine. However for mine, the Material that was previously set up as Enscape material turned into custom material type in rhino, and disappeared from the Enscape material editor. The issue is even after turning back into Enscape material type, some information is missing from the original material set up such as the reflection mapping and the albedo tint color. And even after I re setting up the material into Enscape material and saved the file, when I close and open it again the material switch back again into custom material type.
