Enscape rendering blurry. Appears multiple passes misaligned & creates blurry effect.
Computer: Lenovo C940 15"
Graphics Card: NVIDIA Geforce GTX 1650 with Max-Q design / 4GB GDDR6
Driver: NVIDIA studio driver version 472.39
Processor: Intel i9-9880H CPU @ 2.30GHz
16 GB RAM
OS: Windows 10 Pro
I am using the Enscape plug-in with Rhino and the output is not working. The Rhino 3D model is a building and not terribly large (72 MB). Enscape is functioning, however, the views are blurry and appears (although I am not certain of the exact reason) that multiple layers of the image are misaligned, creating a blurry image. This happens in both the preview and final rendered image.
Things I have tried to correct the issue:
-varied rendering quality
-varied output resolution
-updating the driver
-changing the driver to the gaming driver
-changing from auto graphics card usage to specifying that Rhino is using the NVIDIA graphics card
-detached my second screen to use only one.
None have solved the issue.
Attached are rendered images of the model illustrating the issue. The views are using Enscape predefined materials with box mapping
The general settings for Enscape (option in the enscape tap in Rhino) says that my graphics card does not support Raytracing (see image below), however I am not certain if this is what is causing the problem, and if there is a solution using my current setup.
One of the reasons I got this computer is because it seemed to have exceeded Enscape’s minimum requirements for graphics cards, so I’m surprised this problem persists.
I have searched online and tried many things to troubleshoot this to no avail including adjusting every setting I have found. No luck. I would appreciate any input or possible solutions.
Hi @js2345
I have not been able to reproduce this issue, is this only happening in that project, or in multiple projects for you?
Additionally, for us to better understand this issue, if you haven’t already, please also send in a feedback report including the log files via the Enscape Feedback Button.
Please also add my name, and a link to this thread in the description for context.
Thank you Rick.
I have submitted the issue via the feedback button & mentioned you.
The problem happens with any model on my machine. The images I sent were from a model I made specifically to illustrate the issue and to rule out that it wasn’t related to file size. The only thing in that model is shown in the views sent.
Issue was caused by having the model far from the project origin.
Moving it back to 0,0,0 resolved the issue in this case.
Is there a more convenient way of achieving this fix? i.e Our workflow requires linking models from other disciplines and locating them in real coordinates. Moving the entire model to 0 is not ideal.
Can you temporarily move the Rhino origin?
Can you make enscape only render within a bounding box (like Revit scope box)?
Can you link into a new model at 0,0,0?
I can confirm that relocating the model to 0,0,0 resolved the issue, which I had not considered as a possible problem. Thank you!
